Question about Brother MFC-8460N All-In-One Printer
Document Jam The LCD reads Document Jam. Clear the scanner jam and then press the stop key. There is no paper stuck inside the machine anywhere. I have turned machine off to reset; no luck. When I press the stop key the paper feed cycles and then the error msg comes back.
  • 1 more comment
  • Anonymous Jan 02, 2008
    I have the same problem as Sprucan does. I have tried the solution posted but I still can't get the error to clear.
  • musiciandave Jan 03, 2008
    I have the same problem with the (Document Jam) Clear the scanner jam msg. I would like to know where the sensor is located so that I may clear it or clean it. Thank you for your help.
  • DiveMonterey Feb 16, 2008
    I'm having the same problem. I checked all the paper feed areas...no paper, no scraps, and have blown out all the dust on the entire block! Any other suggestions????
I finally found a black lever that retracts when the paper placed in the ADF moves over it was stuck in the 'down' position. I took tweezers to pull it back up and unstick it. To find the lever open the ADF look above paper feed roller just to the right of the first metal bar with the spring on it.
Posted on Mar 01, 2008
  • Joao Campos Apr 12, 2011
    Thanks. This saved our office. Exact location of the lever applied to our MFC9840-CDW.
  • molrunner
    molrunner Feb 14, 2012
    This was the same issue with us, the little black plastic lever that senses when paper is out does not pop back up immediately after last page and leads to the jam. Seeing about fixing the spring
Follow the advice from Guest above
Posted on Feb 03, 2009
    President:
  • 4,402 Answers
You must have a little piece that broke off or a sensor is blocked with paper dust.
Posted on Dec 03, 2007
Ok, you won't like it but here goes. Under the ADF there is a tension bar that the pictures move through, I thought the tension maybe an issue so I used some scotch tape on each end to hold the tension bar up so the pics could move more easily. I also found out to stop the jamming I pulled the slides in a far as they would go and created a guide made out of cutt stack of post it's anything that is thick enough to work as a guide to ensure the image was straight will work. I put my stack of pics in portait not landscape as I had taped my guide down so the the images went through straight without a problem. I would call this a design flaw since the slides need to come in closer and to work in portait. As is the landscape will not feed the way is should.
Posted on Feb 25, 2010
Has anyone a solution for this problem? having the same problem, cant get rid of it.
Posted on Feb 28, 2008
  • 4 Answers
You may want to take out tray 1 and reset the paper guides. I believe the rear guide is mainly the problem. Unlock the rear guide, make sure the rear is very snug before locking it. Place tray back in printer and hit the Stop key if necessary.
See if error goes away.
Posted on Feb 19, 2008
  • tbertram Feb 28, 2008
    Most people open the top cover to the ADF (automatic document feeder) and check for debris and report there is nothing there. Check under the ADF sometimes paper gets stuck there as well.
Has anyone figured out this sollution yet?  I need help.  I am having the same problem.  Can't figure it out.
Posted on Feb 01, 2008
CHECK 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
shown, then press [Stop].
Pull it gently in either direction.
If you cannot pull the paper out, continue with the steps below.
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
The fax returns to standby mode.
Feb 20, 2012 | Office Equipment & Supplies
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
It says there's a paper jam or a scanner misfeed..but there's nothing there
Paper stuck inside the HP All-in-One can cause jams or also sometimes there are some instruction that get stuck in the printer internal mechanism .
Power off the printer , unplug the power cable. Wait for 30 sec. , Replug the power cable. Power on the printer.
Check for a stuck paper or torn bits of paper.
Clear jam from the back of all-in-one
Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One.Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Gently pull the paper out of the rollers.If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are likely to occur.
Replace the rear door. Gently push the door forward until it snaps into place.
Press OK to continue the current job.
Clear the jam from the automatic document feeder (ADF)
Paper can also jam in the automatic document feeder. Follow the steps below to clear a paper jam in the automatic document feeder(ADF)
Lift the cover of the automatic document feeder.
Reload and test the all-in-one
Once you have removed the jammed paper, verify that the all-in-one is still functioning properly.
Reload the all-in-one with either plain or photo paper.
Print a page from a memory card or the computer.
If you have completed all the steps listed above and are still experiencing a problem contact HP to service the product.
Jan 24, 2010 | HP J3680 Officejet All In One Printer
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Paper won't feed from drawer - stuck on "manual feed"
The readout on my intellifax 2820 says, Document Jam, clear the scanner jam, then press the stop key. I can't get it to clear. What should I do?
May 03, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Document, Jam???
Hey I figured it out. On the top where you insert paper into the automatic document feeder you will notice a small switch. When paper is set in the tray the switch is pressed down. I noticed on mine that the switch had become stuck down. I just used a small push-pin and popped it up. Error message went away.
Feb 01, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC-8460N All-In-One Printer Logo
603 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
