If it is low in freon then recharging is the solution. Hot air blowing can be due to, as you have said, low freon, dirty condenser fins or blocked filter drier. Make sure condenser is clean. Use brush to loosen the lints and dusts then flush it with a pressure washer. Blocked filter drier must be replaced and so with the freon. You will know it when frost appear on one side of the filter.
Just missing the piece that holds the vent in the window for an Everstar portable a/c. Is it...
(More)
Just missing the piece that holds the vent in the window for an Everstar portable a/c. Is it possible to replace?
Installed a new Hunter thermostat a few weeks ago. All was cool (pun intended) until yesterday when...
(More)
Installed a new Hunter thermostat a few weeks ago. All was cool (pun intended) until yesterday when the air was warm to almost hot. Called the Hunter Fan tech line. We reset the thermostat and all was ok until about an hour ago when it started blowing warm air again. Need advice ASAP!
MPMI-10CR-BB6 DONT WORK THE AC DOES NOT TURN ON AND WHEN ITS PLUGGED ALL THE LIGHTS ARE ON, WHY ITS...
(More)
MPMI-10CR-BB6 DONT WORK THE AC DOES NOT TURN ON AND WHEN ITS PLUGGED ALL THE LIGHTS ARE ON, WHY ITS THAT
