Question about Microsoft Excel for PC
When I enter a formula in a cell with the the insert functon device, it does not calculate itself, but shows as text
Eg I entered the following using the insert function device (Fx beside the line)
=FIXED(Value(Left(N2,2))+Value(Right(N2,2)),0,True)
where N2 refers to a string that contains numbers only ("010203")
Instead of returning the Text "4" I only get
=FIXED(Value(Left(N2,2))+Value(Right(N2,2)),0,True) and no calculation.
I can't figure out why this is happening.
  • JImbo2258 Dec 04, 2007
    I didn't realise that you could not enter formulas into a cell formatted as text.
    CNEWTON2 Many thanks
  • 27 Answers
The problem may be that the cell (row or column) has been formatted as Text.
Change the format of the cell to General (or another numeric supported format), then rekey / edit the formula.
Posted on Dec 04, 2007
    Problem Solver:
  • 16 Answers
Is there by any chance a space or any other character before the equals sign? That could cause your formula to display as text.
Need excel formula to calculate 40% of 75743.
1. Enter 40% in cell B2
2. Enter 100 in cell A2
3. In cell C2, enter this formula =(1-B$2)*A2
You may now copy cell C2 downwards.
Apr 01, 2014 | Office Equipment & Supplies
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
Tip
HOW TO COUNT THE OCCURRENCES OF A TEXT STRING
In the cell that you want the result to appear in, enter the appropriate formula from the following examples.
How to Count the Occurrences of a Number
Use this formula
=SUM(IF(range=number,1,0))
where range is the range that you want to search, and number is the number that you want to count.
NOTE: This formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
How to Count the Occurrences of a Text String
Method 1
Use this formula
=SUM(IF(range="text",1,0))
where range is the range that you want to search, and text is the text that you want to find (the text must be enclosed in quotation marks).
NOTE: The above formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
Method 2
Use the COUNTIF() function to count the occurrences of a text string. For example, use the formula
=COUNTIF(range,"text")
where range is the range of cells that you are evaluating, and text is the text string that you want to count instances of (note that text must be enclosed in quotation marks).
Wildcard characters can be used within the COUNTIF function.
The asterisk character (*) represents more than one character. For example, to count all the cells in the range a1:a10 that contain an "x," you can use the following formula:
=COUNTIF(a1:a10,"*x*")
The question mark character (?) can also be used to represent one wildcard character -- for example, to count all cells in the range whose second character is the letter, such as "ax" or "bx."
=COUNTIF(a1:a10,"?x*")
on Nov 11, 2013 | Microsoft Excel Computers & Internet
Tip
Microsoft Shortcut keys for Microsoft Excel
Here's what you are looking for. Browse it and you can find it there all you want for shortcut keys. Follow this link below:
Microsoft Excel Shortcut keys
Enter data by using shortcut keysToPress
Complete a cell entryENTERCancel a cell entryESCRepeat the last actionF4 or CTRL+YStart a new line in the same cellALT+ENTERDelete the character to the left of the insertion point, or delete the selectionBACKSPACEDelete the character to the right of the insertion point, or delete the selectionDELETEDelete text to the end of the lineCTRL+DELETEMove one character up, down, left, or rightArrow keysMove to the beginning of the lineHOMEEdit a cell commentSHIFT+F2Create names from row and column labelsCTRL+SHIFT+F3Fill downCTRL+DFill to the rightCTRL+RFill the selected cell range with the current entryCTRL+ENTERComplete a cell entry and move down in the selectionENTERComplete a cell entry and move up in the selectionSHIFT+ENTERComplete a cell entry and move to the right in the selectionTABComplete a cell entry and move to the left in the selectionSHIFT+TABWork in cells or the formula bar by using shortcut keysToPressStart a formula= (EQUAL SIGN)Cancel an entry in the cell or formula barESCEdit the active cellF2Edit the active cell and then clear it, or delete the preceding character in the active cell as you edit the cell contentsBACKSPACEPaste a name into a formulaF3Define a nameCTRL+F3Calculate all sheets in all open workbooksF9 Calculate the active worksheetSHIFT+F9Insert the AutoSum formulaALT+= (EQUAL SIGN)Enter the dateCTRL+; (SEMICOLON)Enter the timeCTRL+SHIFT+: (COLON)Insert a hyperlinkCTRL+KComplete a cell entryENTERCopy the value from the cell above the active cell into the cell or the formula barCTRL+SHIFT+" (QUOTATION MARK)Alternate between displaying cell values and displaying cell formulasCTRL+` (SINGLE LEFT QUOTATION MARK)Copy a formula from the cell above the active cell into the cell or the formula barCTRL+' (APOSTROPHE)Enter a formula as an array formulaCTRL+SHIFT+ENTERDisplay the Formula Palette after you type a valid function name in a formulaCTRL+AInsert the argument names and parentheses for a function, after you type a valid function name in a formulaCTRL+SHIFT+ADisplay the AutoComplete listALT+DOWN ARROW
on Feb 11, 2011 | Computers & Internet
Problem was found in Micorsoft excel 2003. When I copy the formula from one (original) cell to another (new) cell, the formula in the new cell has updated but the value show on the new cell was the...
Once you have copy the cell from where the formula cam from, on the destination cell,
go to
1. Edit
2. Paste Special
3. Formula.
4. Press Enter
This should resolve your problem. Regards.
Aug 11, 2010 | Microsoft Office Excel 2003 for PC
Sometimes when I use a formula in Excel 2003 it will not calculate - it is as if the formula does not exist. an additional problem is that when the formula works it will not calculate several columns if...
Make sure, when you entr a formula that you hit the ENTER key instead of just moving to tyour next cell. To have all numbers added or moved, use the"Special" application, or change the value. Such as -if you are working in text mode and you enter numbers, they are only numbers in text mode. They don't have a value. Correct the cells to reflect numbers. Right click, format cell - select what you want.
Nov 05, 2009 | Microsoft Office Excel 2003 for PC
When I enter a formula the cell displays the formula and not the result. For instance, I type: =left(L27,13) Instead of showing me the 13 leftmost characters in cell L27, it shows ''=left(L27,13)''. Any...
You can change this under the Excel, options menu. Select the advanced option and uncheck the option to "Show Formulas in cells instead of their calculated value", or you can jjst press Ctrl + `
This will either turn on or off the show formula option.
Apr 27, 2009 | Microsoft Excel for PC
Spreadsheet formulaes
1. enter = symbol
2. enter ( symbol
2. enter cell location where your cost value is
3. enter * symbol
4. enter 0.7
5. enter ) symbol
6. enter 0.175
eg. =(A3*0.7)*0.175 where A3 is the cell location where your cost amount is
Oct 08, 2008 | Microsoft Windows XP Home Edition
Regarding Excel formulas
Yes, its possible by designing a formula in excel.
Aug 03, 2008 | Microsoft Windows XP Professional
Excel calculations
Just enter using this style
TIME IN TIME OUT HOURS 10:00 16:50 6:50 10:22 17:34 7:12 9:00 10:00 1:00
the formula in HOURS is Time Out - Time In
Mar 20, 2008 | Computers & Internet
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
125 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
