Question about Palm LifeDrive Handheld
Palm Lifedrive failure
Lifedrive tries to 'reboot' but never gets beyond the opening screens - stops - there is an audible 'click' and it starts over. It never succeeds. Unit is quite warm in the middle of the back panel. (hard drive? tell me it aint' so!) Battery seems OK but I ordered a new one just in case. KBW in Anchorage kbwitt@att.com 907-229-0459
  • 2 more comments
  • DrChelaGlez Dec 06, 2007
    LD reset, but will not reboot. Have tried charging but to no avail!
  • HSMax Dec 10, 2007
    LD reset tries to 'reboot' but never gets beyond the opening screens - stops -
    there -- frozen. It never succeeds. Unit
    is quite warm in the middle of the back panel. Must charge battery and, then to shutoff must run down the charge . Battery seems OK.
  • 337shout Dec 19, 2007
    I am experiencing the same problem. I ran down the battery to see if it would possibly reboot properly after that, but still get stuck on the Palm screen after hearing a few clicks.
  • Fernanda8 Feb 06, 2008
    I have the same problem! I couldn't find the hard drive on the palmparts.com page. How do I find out if my palm is still under warranty?
  • 59 Answers
I found this on the Palm website about the frozen Palm Logo screen
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=97,E=0000000000825271086,K=7324,Sxi=2,Case=Obj(26419)
Posted on Jan 07, 2008
  • Eduard Vander Smitte
    Eduard Vander Smitte Jan 07, 2008
    Link didn't fit -
    http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.E...
THE PROBLEM
LD reset tries to 'reboot' but never gets beyond the opening screens - stops - there -- frozen. It never succeeds. Unit is quite warm in the middle of the back panel. Must charge battery and, then to shutoff must run down the charge . Battery seems OK.
YOUR ANSWER
sounds like the internal harddrive Palm Lifedrive failure - clip_image001.gif failed you can purchase a new one from pdaparts,com...theres two different flavors the standard cf or the usual harddrive i went for the cf less battery drain that way
WHAT IS CF
Posted on Feb 01, 2008
  • joe pagliaro Jun 08, 2014
    cf= compact flash
  • 4 Answers
Sounds like the internal harddrive failed you can purchase a new one from pdaparts,com...theres two different flavors the standard cf or the usual harddrive i went for the cf less battery drain that way
Posted on Jan 31, 2008
My Palm Lifedrive handheld is frozen and if i put in my password,it will not register as i tap the screen.Can i get help?
Hi you should update the software of the Palm Lifedrive Handheld you can got to manufacturer website and download the software.
Aug 04, 2010 | Palm LifeDrive Handheld
Palm life drive frozen on "palm one "screen
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your lifedrive, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm LifeDrive Handheld
My lifedrive seems to have developed a mind of its own. Calibration is off and it just randomly clicks on items and goes to the program associated with it.
That can be from a couple of things. If you have a screen protector on try taking it off. Also check for crud under the buttons. I've had it caused by both. The screen protector was perfectly in place and this stopped the instant I pulled it off.
It is possible it is a fault in the digitzer hardware but that is quite uncommon and requires replacement.
Jan 20, 2010 | Palm LifeDrive Mobile Manager Handheld
It reset and is now stuck on the 1st lifedrive screen and wont go any further
HI there,
Normal 0 The best thing I can offer for you to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Here is that link.....
Normal 0 http://kb.palm.com/wps/portal/kb/na/lifedrive/lifedrive/unlocked/supportservices/page_en.html
Nov 23, 2009 | Palm LifeDrive Mobile Manager Handheld
Palm lifedrive wont' boot stuck on palm screen
This sounds like the issue where the LifeDrive is stuck in a loop. You can see how to break the device out of the system loop on the Palm Knowledge Base article (26419) located HERE.
Hope that helps get you up and running again!
Sep 12, 2009 | Palm LifeDrive Mobile Manager Handheld
Lifedrive Re-booting
I had the same problem and it was the battery.......
Sep 24, 2008 | Palm LifeDrive Mobile Manager Handheld
Palm lifedrive frozen 'secure erase'
You may be experiecing failure of the microdrive. Those are typical of it failing or having failed.
Having said that have your tried the hard reset buy holding the 5 way down while sliding the power switch? This is slightly different than the older secure but you need the update 2 to have it. This will erase and reformat and reload the entire system a bit more thouroughly than the older secure erase.
It might get you out of the cycle which is more important.
Feb 16, 2008 | Palm LifeDrive Handheld
Rebooting problem
From Palms website-
Dec 25, 2007 | Palm LifeDrive Handheld
Not rebooting
This is what Palm has to say about it
Palm LifeDrive dead
You may be stuck in a loop-
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=2,E=0000000000825355002,K=8658,Sxi=6,Case=Obj(26419)
After you do a hard reset, try naming the palm something other than what the name was before hand and see if that profile works.
Oct 24, 2007 | Palm LifeDrive Handheld
Palm LifeDrive Handheld Logo
389 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
