i replaced the convergence chips and diodes my screen looks greaty but i am having a little trouble tuning the color! i am trying to do it without the philips remote! i have it very close manualy adjusting the guns but it looks like the colors wont line up verticaly, please help
Hi, if the green isn't straight to begin with you will need to go into the convergence sub menu and align it there code is 062597 status then follow the instructions to adjust the green first, then red , then blue multipoint and save it.
pressing menu to switch arrows to move/adjust status to back up , make sure to scroll down to save multipoint before exiting, power off when done.
If any color will not move or is more than 1 inch out of adjustment you may need to check the resistors to that convergence color .
hope this helps
Eric
Hi I hope after replacing the IC’s you also cleaned your solder points with the alcohol. Many people have also had blown resistors requiring replacement. About the IC's- If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice. If you have done the repair and know that it was done correctly then it means it is definitely the remote issue and unfortunately you’ll require a Philips Remote. Please do accept the solution if the issue is resolved or else revert for further assistance. Thanks Rylee
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
thank you for your help
" - rex_aldrich
Popular Solutions for Philips 55PP9401 55 in. Rear
Philips 55PP9401 55 in. Rear Projection Television
We have an JVC rear projection TV - about 4 years old. Three days ago the red color went out....
(More)
We have an JVC rear projection TV - about 4 years old. Three days ago the red color went out. Everything else is OK. We tried reconnecting it so it would go through a different source, but that didn't help. Any more ideas?
Hi, I've a Philips Projection TV PTV392, model 52LP50. The problem is that blue ace is down than...
(More)
Hi, I've a Philips Projection TV PTV392, model 52LP50. The problem is that blue ace is down than green ace and red ace is up green ace. How I can align blue and red aces with green ace?
i have a 55pp9352 and the red went out of wack and its to far out to bring it back with the remot...
(More)
i have a 55pp9352 and the red went out of wack and its to far out to bring it back with the remot HELP
