Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Intel Media Series Intel G33 chipset micro atx no post no boot after crazy fan
I just build a new system with Intel mobo and core 2 duo 6750 cpu. After everyhting is in place, I turn the system on and no beep, the fan was running very fast and loud. I was afraid that the cpu was burn, so I immediately turn off the machine. after that I re sit the cpu and try to turn on the system.
Nothing happened, no beep, no post, no led light, no power to the fan.
is my cpu fired, or its just faulty mobo? I suspect its the mobo since there is no beep in the first place. But maybe I am wrong. Has anyone has the same problem?
Intel DG33TL, Gskill 2gb RAM pc6400,core 2 duo 6750
  • 1 more comment
  • ojup Dec 04, 2007
    thanks campus, but I always exclude all additional card when building a machine so, the are no cards in the mobo when I turn it on.
    And all necessary cable is inserted. can it be a bad CPU or RAM?
  • ojup Dec 04, 2007
    The speaker is build in the board, so I assume its enable by default.
    I just check again there was a small led on the board next to the 24 pin header lights on when I turn on the machine, but all case led and all fans seems does not get any juice.
  • ojup Dec 04, 2007
    At this point I am going to RMA the board
  • 205 Answers
Campus is giving you good advice. The only thing I'll add is that there are two power supply cables that connect to the motherboard. The first time I built a computer I did not realize this and I only plugged in the larger ATX cable. There is also a small square power supply cable. If you've already plugged them both in and you hear nothing when you turn on the power then the motherboard is probably bad.
Posted on Dec 04, 2007
  • ohiotom Dec 04, 2007
    I don't think it's the CPU or RAM. The POST (Power On Self Test) should beep to indicate that a problem with RAM or CPU exists.
    I know this may be a stupid question, but do you have a speaker plugged in to the motherboard?
  • 56 Answers
Make sure you have seated all the cards properly, take them out and reseat them including the ram. Make sure your IDE cables are plugged in properly as well.
Restart the computer and if still no post then yes unfortunatly for you its the mobo =(
Intel E5800 wont work with Acer Veriton M460 SPECS BELOW
eric, Belarc will give you a comprehensive picture of your computer. GL
Jan 22, 2014 | Acer Veriton M460 Micro Tower Core 2 DUO...
..................My system config is : Intel C2D E7500 with 2.93 GHz CPU MOBO is Intel DG41RQ and 2gb DDR2 RAM OS is Windows XP - 32-bit (Service pack 3) .Problem is iwant to buy a new graphics card
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 10, 2013 | Intel DG41RQ Motherboard & Core 2 Duo...
Need to find witch motherboard fits gateway computor M-6843
http://support.gateway.com/s/Mobile/2008/Avalon/1015608R/1015608Rnv.shtml
Click on Components in the list.
Scroll down to -
Motherboard:
4006229R - Motherboard GM965 Chipset Intel Video W/10/100LAN No HDMI (FRU)
Click on the above.
Main View
Specifications
http://www.buy.com/prod/gateway-4006229r-gateway-m-6750-m-6755-m-6834-m-6823a-m-6846/209257968.html
http://www.codemicro.com/store/product/Gateway-4006229R-New.php
http://www.ebay.com/itm/Gateway-M-6750-Motherboard-31SA1MB0030-DA0SA1MB6E0-IS-read-carefully-/261119779234?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D3052480971542613513%26pid%3D100011%26prg%3D1005%26rk%3D2%26sd%3D270875445041%26
Just from some quick searches. Note that -
31SA1MB0030 is also another reference number.
May I ask what the problem is?
Power problem?
Do you have decent soldering/un-soldering skills?
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Computers & Internet
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Please, I am need manual mother board MSI G31M3-L V2. Obrigado!
http://www.msi.com/service/download/manual-8486.html
then select US
see page 1 of pdf document.
INTRODUCTION
Thank you for choosing the G31M3 V2 Series (MS-7529 v1.x) Micro-ATX mainboard. The
G31M3 V2 Series are based on Intel
® G31 & Intel® ICH7 chipsets for optimal system
efficiency. Designed to fit the advanced Intel
® CoreTM 2 Duo/ CoreTM 2 Quad/ Pentium
Dual-Core E2XXX and Celeron 4XXX/ Wolfdale Series LGA 775 processor, the G31M3 V2
Series deliver a high performance and professional desktop platform solution.
Apr 24, 2011 | MSI G31M3-L V2 Motherboard
I carnt work out what size chip to put on the p5s-mx se Socket LGA775 motherboard
Ok no problem I can help you there. First you want Intel or AMD. I would take Intel. Then you want Core Duo or Core 2 Duo, I'd take Intel Core 2 Duo, then you need to find out the Frontside Bus Speed of your motherboard, it has to match the CPU. So let's say its 1,066MHz. And you want something faster than 1.8 so go with 2.4GHz. So now we looking for a Intel Core 2 Duo, 2.4GHz, 1066MHz bus speed with stock cooler. So then go to www.intel.com, in their search box type "Intel Core 2 Duo 2.4Ghz" and it will bring up all the CPU's and their prices..if you have any questions let me know. Pls rate this solution.
May 11, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : it_mid@yahoo.com
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
MSI has two boards P4M900M3-F, P4M900M3-L.
Both of this will support your CPU
Nov 26, 2008 | MSI Computers & Internet
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
162 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
