Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Cold feed only
Can i move my wd64 (washer dryer) to my utility room that has a cold water feed only?
    President:
  • 4,402 Answers
I don't see why not, you only be able to wash in cold water and i hope u have a drain and power in that room.
Posted on Dec 03, 2007
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
Jul 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Hoover HW160m - double inlet but only 1 tap at new build.
You can use the cold water only with no issues at all. The only thing you will have to do is buy a cap to block off the hot water inlet on the back of the machine otherwise the cold water will flow out through it onto your floor etc.
And yes, your machine has an element built in which will heat the water for you!
Regards,
Adrian.
Jun 18, 2009 | Hoover HW160M Front Load Washer / Dryer
Clothes wont dry but gets really hot
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
MY WD64 does not spin
First see if there is power in your wall socket; then check your washer plug, or plug fuse, wires.......
Sep 30, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
90 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
