Question about HP Officejet 7130 All-In-One InkJet Printer
Not reading photo card
Since it's not reading my photo card, I tried to re-install Hp Software as instructed. The problem is I cannot uninstall the current software. When I go to my computer, add/remove programs, there is no option to change/remove program when I scroll down to HP Office Jet 7100 series.
How do I uninstall it!!
  • Muscay1 Dec 27, 2007
    I tried getting a new install cd from HP and still have the same problems. It tells me on the pc that the HP installer has already installed the software. But its not there. I cannot install , nor can I uninstall the software.
  • 42 Answers
Hey,
have you tried to insert the hp install cd, normalcy there are an uninstall button?
best regards michael
miguelovitch amplifiers
Posted on Dec 03, 2007
Installing Palm T|X software killed my USB. How can I get it back?
Uninstall the software and read the instruction care fully before installing the software.
Jan 12, 2011 | HP Compaq Presario SR1110NX PC Desktop
Windows xp will not install my hp officejet 7310 all-in-one printer after i uninstallit? i keep getting a 1603 error or can't remove the old webreg?
If problems arise while installing or uninstalling the software, download this removal utility to uninstall the HP All-in-One software before attempting software reinstallation. IMPORTANT NOTE:
This utility removes only version 4.2.0 of the driver.
Running the removal utility may remove the drivers and software for other HP printing, scanning or digital imaging products.
This utility works in stages. The first time the utility is used, it runs at level one. The next time the utility is used, it runs at level two. There are four levels. The effects of each level are shown in the table below.
Uninstaller level Description 1 Removes the Windows device discovery (Plug and Play) entries from the Windows registry. After running level 1, connect the USB cable to the all-in-one and let Windows try to discover the device again. 2 Performs Level 1 and removes the software drivers. After running level 2, run the all-in-one installer and use the "Add a new device" option to attempt to reinstall the all-in-one again. 3 Performs Levels 1 and 2 and removes the HP Photo and Imaging software. You must completely reinstall the all-in-one software after running level 3. 4 Performs Levels 1, 2 and 3, and removes HP Software Update. You must completely reinstall the all-in-one software after running level 4. Installation instructions:
  1. Click the Download now button.
  2. When prompted, choose Open or Run to start the download and run the installer.
  3. Follow the onscreen instructions.
Details and specifications File name: s.gif gr_uninst.exe [1/1, 866.52k] Released: s.gif 2005-01-11 Version: s.gif 4.2.1 Compatibility: s.gif Microsoft Windows XP, Microsoft Windows 2000
Dec 20, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I have a HP M525 camera, Seerial No. CNGBUQ30Z4. Recently, when trying to transfer some up-loaded picturs (from the camera to the computer)the screen went blank. When I tried to restart the process by...
The possible solution's are
1 . First uninstall the photosmart software from the system and reinstall the software once again . Install in C: drive and then connect usb and transfer photos this will work . If this doesn't work then try in another usb port of the computer and transfer photo's .
2. Photo's will be in memory card ,better get memory card reader and take out the memory card from the camera and insert it into the card reader . Now connect card reader to computer and transfer photo's .
Hope this helps .
Mar 23, 2010 | Cameras
When I install the D7260 printer using the CD-Rom supplied it works fine. Then after a few days only the top two or three lines of the first page are printed and, after a long pause, the sheet comes out....
Many issues are caused when the HP Photosmart is connected to computer using a USB cable before the HP Photosmart software is installed on the computer. IF you connected the HP Photo smart to your computer before the software installation screen prompts you to do so, you must follow these steps.
Troubleshooting common setup issues :
1) Discoonect the USB cable from the computer.
2) Uninstall the software (if you have already installed it.)
3) Restart you computer.
4) Turn off the HP Photosmartm wait one minute then turn it on.
5) Reinstall the HP Photosmart software.
If your installation is incomplete, or if you connected the USB cable to the computer before prompted by the software installation screen, you might need to uninstall and reinstall the software. Do not simply delete the Hp Photosmart application files from your computer. Make sure to remove them properly using the uninstall utility provided when you installed the software that came with the HP Photosmart.
To uninstall from a Window computer and then reinstall
1) On the Windows taskbar, click Start, Settings, Control Panel (or just Control Panel).
2) Double-click Add/Remove Programs (or click Uninstall a program).
3) Select HP Photosmart Driver Software, and then click Change/ Remove.
4) Disconnect the HP Photosmart from your computer.
5) Restart your computer.
Note : It is important to that you disconnect the HP Photosmart before restaring your computer. Do not connect the HP Photosmart to your computer untill after you have reinstalled the software.
6) Insert the HP Photosmart CD-ROM into your computer's CD-ROM drive and then start the Setup program,
7) Follow the onscreen instructions and the instructions provided in the Setup Guide that came with the HP Photosmart.
Nov 09, 2009 | HP Photosmart D7260 Printer
Printer will not save photos to computer
For whatever reason, it sounds like the printer cannot communicate with the computer. Check all the wire connections. If all connections are good, try printing a test page using Word. If you can print a test page, that shows everything is workign properly. Next, try uninstalling and reinstalling the software that came with your printer. If you do all these things, that should fix the problem unless there is something wrong with the printer hardware. Good luck.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP PHotosmart 8450 problem: not reading memory card
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00001878&lc=en&cc=us&dlc=en&product=402150&rule=21476&lang=en
Above is the link to the HP Support site pertaining to your printer. It contains all the details on how to re-isnstall the software and drivers.
From what I have researched on your model I suggest you completely uninstall all the software and drivers for your printer and the re-install them. This will resolve your issue for you. Below is the link for all the most current software and drivers for your model. Simply pick the link on the site for your particular operating system you are using the printer on.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&docname=c00001878&dlc=en&product=402150&rule=21476&lang=en&
This will almost undoubtably solve your problem assuming the printer has no electronic malfunctions. If you need any further assistance feel free to contact me and I will call you and walk you through the repair step by step live. Please don't forget to give me a FixYa rating when we get this printer going for you.
George
Jul 16, 2008 | HP Photosmart 8450 InkJet Printer
Trouble downloading photos to computer
either install manuf software or buy a memory card reader which is plug and play no software to transfers pics into xp or vista
May 17, 2008 | Canon Cameras
Scanner problems
Try completely uninstalling the product and reboot. Reinstall your disk.
If this does not work, please share your OS and scanner/printer brand and model.
Feb 08, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Scanner
1. Create a new user, login and try to use the software...the user profile you are using could be corrupt...I have seen HP Director act really strange due to a profile problem
2. Fully uninstall the software via Add/Remove Programs, rebooting. Re-installing the software, rebooting then trying the program again.
3. Try the device in a different USB port (force the hardware to reinstall in a default style.
Hope this helps!
Oct 10, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 7130 All-In-One InkJet Printer Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
