Question about Apple iPod mini M9160LL/A MP3 Player
Ipod is frozen on now playing w/out playing and wont connect to pc.Is there a reset botton or procedure?
  • MauiMcgyver Dec 03, 2007
    I used suggestion #1 and reset. Worked ,Thanks
  • alphonse dinesh May 11, 2010
    I formated ipod. Now there is no songs in my ipod, When i copy songs from pc to ipod. that songs are not displaying in my ipod. please tell me how to store songs again?
  • 22 Answers
This is a common problem with the ipod mini. luckily it is easy to fix :) to reset the ipod; toggle the hold switch on then off, then hold the center button and play/pause at the same time until you see the apple logo this could take up to 10 seconds. you may need to repeat the procedure. and your ipod will still have all its data but should work like new!
contact me if you have questions or if it doesnt work as you hoped, and i can give you further help!
Posted on Jan 13, 2008
I plugged my iPod in and it refused to play and I discovered the volume is off on the player as in it wont respond at all. If this was a computer, I'd say it had frozen
Press and hold the two buttons circled in red together for about 5 seconds to restart the ipod.
Ipods freeze from time to time and this procedure restarts them.
Aug 30, 2011 | Audio Players & Recorders
My 3rd gen. ipod nano is frozen
just press the menu and power botton at the same time. that reset your Ipod
Aug 13, 2009 | Apple iPod nano 3rd Generation
My ipod nano is stuck on language selection and is frozen can you help me?
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    Hope i helped you.
Thanks.
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Pink ipod 8GB frozen on language screen
just try to reset you ipod by pressing play and menu button simulaneously for 5 seconds and it'll restart then again if it's hanging there hold play button during bootup then enter bios mode from there u can connect to pc n restore the software
Jun 09, 2009 | Apple iPod nano 3rd Generation
My ipod nano third generation is frozen
You should not plug the ipod to pc while it is playing because it is switches from the playing mode to sync and charging mode you can not play and use the ipod while it is connected with the software without ejecting it from itunes. Do a reset by pressing and holding the center and menu buttons at the same time until the screen goes back and apple logo pops up. This should reset your ipod and fix the problem.
Feb 20, 2009 | Apple iPod nano
Frozen screen
First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
Nick
Jan 22, 2009 | Apple iPod nano
Ipod 30gb video black
Try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 15, 2008 | Apple iPod MA446LL/A MP3 Player
APPLE IPOD NANO
Try pressing the menu button and center button together until the Master Reset begins
Feb 27, 2008 | Audio Players & Recorders
Frozen iPod nano
try to put the ipod into disk mode, while connected to PC, perform first hard reset by holding select and menu buttons until it restarts, when quickly change to pressing select and play buttons, then it must go into disk mode, will sync with PC and must show in iTunes, perform restore function to reformat the memory
Aug 18, 2007 | Apple iPod nano
Apple iPod mini M9160LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
