There are two ways of turning this tv off. A "Main Power" button directly on the TV which turns it completely off or using the "Standby" (a mode which turns the TV off, but will leave a red light at the bottom of the screen) mode which is activated when using the TV remote's Power button or to press the Standby button on the TV. The only way to turn on the TV with the remote is to leave it on Standby mode, and that has been fine for the long time I have owned this TV. But one night I used the remote to turn it off (putting it on standby mode) and quickly remembered something I wanted to record (with my DVR). When I used the remote to turn it back on it turned on normaly, but then quickly shut back down to Standby mode. I tried turning it back on using the remote, but the button was not doing anything. I tried pressing the Standby button on the TV but that didn't work either. I then pressed the Main Power button on the TV and the TV shut down normally. When I pressed the Main Power button again it seemed as if it were working normally but then it shut back down into Standby Mode.
I've tried unplugging it and plugging it back in and that didn't work. Everything plugged into the TV is working fine, I just can't turn on the TV.
I have just ordered two new convergence IC's for my Pioneer SD-533HD5, rear projection TV and I...
(More)
I have just ordered two new convergence IC's for my Pioneer SD-533HD5, rear projection TV and I would like to know how to proceed to complete the repair. Thank you in advance for your support.
Where are the convergence IC's located and what is the recommended procedure to accomplish the above...
(More)
Where are the convergence IC's located and what is the recommended procedure to accomplish the above mentioned task? Thank you in advance. Adrian Vlake
the guy that im getting the tv from said something needs soldiered on the on/off switch it's a...
(More)
the guy that im getting the tv from said something needs soldiered on the on/off switch it's a pioneer 533hd5 53''
Hi, I am looking to buy a used 53" Pioneer rear projection TV, but the problem is: Once you...
(More)
Hi, I am looking to buy a used 53" Pioneer rear projection TV, but the problem is: Once you turn it off you need to wait an hour before turning it on again or it will blow a fuse. The fuse is easy to change, but what's the problem?
when television is turned on it turns right back off. we replace the fuse that was blown but it blew...
(More)
WHEN TELEVISION IS TURNED ON IT TURNS RIGHT BACK OFF. WE REPLACE THE FUSE THAT WAS BLOWN BUT IT BLEW AGAIN WHENT THE TV WAS TURNED ON AGAIN
