Question about Whirlpool LSB6200PQ Top Load Washer
RE: Putting whirlpool washer back together
I took my old Whirlpool washer apart to fix a drain hose that had come unclamped. My big problem now is trying to get it back together like it was before. (It is 21 years old). I followed directions on a web site with pictures. We can't seem to get the outside case to lock down. I can see there is a slot in the outside case way in the back that is supposed to fit over a little rise in the bottom of the rail of the inside washing machine itself, but as soon as we get one side locked in, the other one springs off. Same with the spring clips. I get one clip in and the other springs off. I think something must not be lined up quite right--it can't be this hard if one man can repair it and get it back together. (it has been rebuilt before) and got it back together. I would appreciate any suggestions.
  • lorsuj Dec 13, 2007
    Thanks for your answer. I was trying to put the outside cabinet back on. Had trouble aligning the back of the cabinet with the back panel and getting the spring clips back on, but I did finally get it back on, not perfectly, one side just won't lock down. If I get one side on, the other side springs off (this is where it sits on the side rails). But it's working fine. I've been washing clothes in it.
  • Anonymous Sep 01, 2008
    I'm having trouble reconnecting the drain hose properly. The washer won't drain out the water during the spin cycle unless the drain hose is lowered into a pail - which takes forever to completely drain the washer tub. Originally there was a clog in the hose, but now the clog is removed and I can't get the hose reconnected properly. Should the hose resemble an 'S' to ensure necessary drainage?
  • 770 Answers
Ok I know this is a problem heel i had trouble doing y first few but i learned a trick 1. make sure your front feet are off the ground at least 1/2 inch if they are rusted or broken place a screwdriver under the black rails. ok 2. wirh the cab. in front of you open the lid andhold it under that lip tilt it forward and then slide it toward the unit look down the lid hole you want the front edge to line up first as you slide it down there are two flat pins sticking up on both sides about 7" back fron the front corners these must fit into the cabniet you then drop it down slowly put the left clip on first then place you hand down the back right side pull it forward and install your other clip one note the fill dispenser will need to get under the cabniet before it will seat properly. connect your lid sw and close the console. let me know if this works and please rate this help
Thanks Gary
Posted on Dec 13, 2007
    Problem Solver:
  • 17 Answers
What area are you talking about getting the transmission back in or the clutch (Basket Drive) for a hose change out maybe either? need some more details
Posted on Dec 10, 2007
2 Suggested Answers
Lumpy816
  • 246 Answers
SOURCE: RE: Putting whirlpool washer back together
I would agree with you, it sounds like it isn't going back together correctly. When I put the cabinets back on them, I first make sure all 4 of the spades sticking up from the base are straight and not bent over. Next I grasp the hole the lid covers towards the front and lift and pull it towards me so the bottom of the cabinet is closer to me than the top. Next, I use my foot to push the bottom of the cabinet under the bar that goes across the base of the machine. Then I tilt the top of the washer back towards the machine. I wiggle the sides, until the cabinet seats into the spades coming from the base. After it seats properly, the clips should be lined up properly to be installed.
Posted on Jul 01, 2008
IT ONLY DOES THE WASH MODE THEN IT STOPS. DOES NOT RINSE OR DRAIN WATER. I TOOK IT OUTSIDE AND THE WATER DRAINED THROUGH THE DRAIN HOSE. BOTH HOSES GOING TO PUMP ARE CLEAR. ANY SOLUTIONS????
Eddie,
Is this by chance a Whirlpool or Kenmore washer? If so, a frequent problem is the lid switch. It can either have a loose lid which allows the plunger that activates the switch, miss the switch when you close the lid, or you might have a bad switch. One of the things that I have done for several customers is to repair the switch with a plastic zip tie. What happens occasionally is that the switch will split along the seam where it is glued together and when the lid closes, the plunger pushes the two halves of the switch apart and does not make contact. Putting a zip tie around that switch will eliminate that problem and possibly fix your problem. The washer may think that your lid is still up and that could be why it does not complete the cycle. Hope this helps!
Mar 10, 2015 | Washing Machines
Washer agitates but will not spin drain spin or fill
Well I have a Roper Top Load Washer, bought it in 1998 ,no problems til back 6 years ago we had someone come fix it. My problem was the same wouldn't drain or spin. The problem was it was clogged, in the front when you lift off the washer casing theres a white piece connected to to tubes that drain. well there was my daughters pair of underwear in there and a couple small socks. He took them out put it back together and worked ever since. Until earlier tonight we had same problem so we took it apart ourselves and found my boyfriends sock in there took it out and put it back together and works great again. So far so good. Hope this helps Good luck. Tammy
Nov 05, 2010 | Whirlpool LSR8433K Top Load Washer
I'll find water in the tank when the washer is off. I will put it on the drain cycle to drain the water. Come back about 6 plus hours later to find water in the tank. Possessed washer?! Took apart the...
u prop need a new fil valve,, it the part that the hoses connect to on the back of the washer, u can remove the top three screws on back for top and acess the valve. if that valve is defective and not shuttting off then water will continue to enter.. hope this helps
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Clutch Problem
H i there.........it sounds as if your incorrectly assembling the clutch ....there is a diagram with the new clutch....no its part of the assembly
regards Sir Galahad
Aug 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Dish washer draining water from the top of sink.
i had the same problem. took apart the inside pipes but did not work . outside my kitchen sink there is a clean out . got a big wrench and opened it up , took the water hose and put it inside the cleanout. Oh my gosh ! it was so yucky.. but it worked. hope this helps.
May 17, 2009 | Whirlpool Dishwashers
Hose on whirlpool washing machine
To the pump at your drain line. up top.
Feb 14, 2009 | Washing Machines
Our Whirlpool washer won't drain
this machine has the pump directly atached to the pump assy, so if the motor is runnning your pump will drain water. more likely is that when you put the unit back together perhaps you didnt plug the lid switch assembly bak in. if there is no lid switch detected the unit will not drain or spin and when it gets to that mode it will simply stall out. no noise or anything. will fill, agitate but not spin and/or drain/ check the lid switch!
Nov 11, 2008 | Whirlpool Ultimate Care II GSQ9669L Top...
FL ERROR CODE - Machine is about 5-6 yrs. old.
I just had this issue two days ago. You have to take the back off the machine. If you have water then drain manually. I did this by taking the drain hose, pulling through the housing, unclipping the hose from the inside of the machine. This will get the hose to ground level, and using a bucket dip the hose down to fill, and up to drain into a bucket. This was time consuming, but it did almost fully drain. I then tipped the washer on its front, and took the bottom cover off. You will see two hoses, going to the pump motor. Remove the hoses, and you will have access to the pump impeller. I removed the entire pump and motor to clean it out. If you do this be careful. I had to find the wiring diagram to reconnect the wires. After pulling out a draw string from a swimming suit, and putting the machine back together it all worked. The repair sheet for this machine is taped to the front panel of the machine. This has all error codes, diagnostic modes, and anything else you will need to know to fix this machine. To get to the sheet, pry off the whirlpool emblem with a flat head screw driver. Remove the screw and lift up the top cover just enough to get the sheet. The sheet is in a plastic bag attached to front panel on your left as you are looking at the machine. Good Luck with the repair. Also check the actual drain hose for a clog. I found a piece of a sock in mine.
Jul 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Jun 30, 2008 | Kenmore 24032\24036 Top Load Washer
My roommate removed the water in hose and I need to find a manual to put it back together
starslight07 You can find the repair manual for your washer here: http://tinyurl.com/32d5lu Good luck. Gendos
Jul 06, 2007 | Whirlpool LSR9434PQ Top Load Washer
Whirlpool LSB6200PQ Top Load Washer Logo
1,776 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
