Question about Miele Novotronic T220 Electric Dryer
Miele T 1515 electric dryer
Problem with drum noise. A small reverberation sound. Drum turns but rubbing. I have taken top off and noticed slight movement of drum, front to back. If I apply slight pressure with my knee at the back of the dryer at the axis point of the drum, the sound returns to normal. Any suggestions?
  • 16 Answers
Blower fan has fluff on stuck to it. It may even be disstorted. If you are really unlucky then it's done the blower fan motor bearings as well.
Posted on Feb 08, 2008
Drum turns but sounds like a small metal object, possibly a screw, banging around inside . Continued to use and now sound is much louder and sounds like a bigger object.
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
Jun 27, 2014 | General Electric Profile DPSR610EGWT 7.0...
Dryer sounds like metal rubbing, drum in a bind. The drum is turning, but making a sound, like metal to metal, especially when it starts up.
You have a bad drum bearing. When it heats up the sound goes away slightly. When the drum bearing goes bad it tilts the drum in the front and it is rubbing on the metal front. Check the seal in the front. You could use lub spray but that is only preventing the inedible-replacement. Good luck.
Jul 10, 2010 | Crosley CDE6000 Electric Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Hotpoint ultime wt640 has a slight squeek seem to be on front around door area had top off and turned drum motor and drum seem fine and springs ok
Remove rear cover of washer, remove drum belt,and from front of washer, spin drum by hand.
There should be no noticeable noise.
If you can still hear sqeek, then it could be a drum bearing that is dry or starting to fail. or the drum is rubbing on the front of the door seal
You should be able to detect what it is this way.
Please rate my solution.
Thankyou.
Jan 17, 2010 | Hotpoint Aquarius WD640 Front Load...
Whirlpool Dryer making a rubbing or jingle noise when running
there are wheels under the drum to support it take the front panel off and check those
Jun 24, 2009 | Whirlpool GEW9200L Electric Dryer
When turning, loud grinding noise.
Can be a tensioner pulley with bad bearings or the rear drum bearing is shot. When the rear drum bearing goes bad, the drum drops slightly and starts rubbing and making all sorts of terrible noises. I would not run it like this as the pivot on the rear of the drum that rides in the bearing could be cutting into the support. Not a good thing.
Good Luck and hope this helps.
Mar 15, 2009 | Whirlpool LER4634J Electric Dryer
Unable to take drum out to inspect issue
lewis your almost there.the noise is a roller/wheel .unplug unit pop the top remove the frount panels.this will expose the drum.remove the belt and then you will have exposed all the moving parts inspect clean and replace as needed.you can do it yes we can
Dec 31, 2008 | Dryers
I HAVE DRYER GE MOD #DWSR488EB2WW SER#ZG743601A ***HAVE GRINDING NOISE. RELPACED THE BEARING IN THE BACK. BELT SEEMS OK. PUT BACK TOGETHER NOISE CONTINUED. THE NOISE HAS A SLIGHT GRIND/SCRAPE IN ONLY PART...
The most likely cause is the front drum supports. There are 3 or 4 teflon strips (about a half inch wide and 2 inches long) on the top of the front panel that the dryer drum glides on. When these wear down, the drum can scrape on the plastic that holds them or on the metal frame around the door frame. Another possibility is if the drum touches the dryer exhaust vent pipe, most often only if the dryer is vented out the bottom of the dryer and the vent pipe has shifted up just a bit, allowing it to contact a spot on the drum with each revolution.
Oct 02, 2008 | Dryers
Miele Novotronic T220 Electric Dryer Logo
518 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
