Question about Umax Astra 3400 Flatbed Scanner
Battery wont stay charge
Changed starter motor and still the battery dyes out
  • 62 Answers
Um... guessing that you are refering to a car or truck, I would say to have the altinator checked out. If it is bad it will drain even a new battery in just a few min.
Posted on Apr 29, 2008
Citroen c4 coupe car wont start when engine is hot/starts fine when engine is cool or cold have changed starter motor fuse no change
check electronic spark unit ie coil pack going open circuit when hot
will run but when turned off will stay open circuit untill cools down then closed circuit then will wprk fine
Aug 17, 2012 | 2006 Citroen C4 1.6i
Hyosung GV 650 wont start. Battery is fully charged and starter don't even click when trying to start?
This will be either the starter solenoid is faulty or the starter motor needs replacing.Have the solenoid checked before removing the starter motor.
Mar 21, 2012 | Hyosung GV 650 Aquila Motorcycles
Don't know where or what the starter motor looks like, does anyone know how to change the starter on a gilera 180 dna/ the thing wont start but i hear a faint clicking when i try to start to turn it over....
The clicking you can hear is the relay actuating when you press the starter button, your problem is more than likely to be the battery being low on charge and not having enough power to turn the starter motor. Fully charge the battery and it should fire up fine. If it dont get a new battery.
Aug 23, 2017 | 1992 Gilera Saturno Bialbero
I changed the motor and now it wont start, it wont turn over at all, it wont crank, the starter wont turn over
Check all wiring. wiring to starter from switch, check if nuetral safety swith is connected. be sure wiring harness at the switch is ok. is battery charged?
Jan 10, 2011 | 2000 Volkswagen Jetta TDI
The engine was running. i turned it off to get something. came back and it wont start. All lights come on bright , engine makes a single loud click and wont turn over.
This sounds like a bad starter or bad battery connections, make sure the battery is charged, and when you crank the motor make sure the lights dont go out, turn them on and have someone watch to see if they dim out if they stay bright then starter is bad .
Oct 10, 2010 | 2001 Dodge Durango
I think my starter motor has gone? my car wont start unless i pus it and kick start it in gear. Is it the starter motor gone or battery playing up??
hi...
both may be the reason for not starting.
11.please check the terminals from the battery,wires and all in good order.then check the volt comin to the starter motor if the volts are correct then the problem is with the started motor. please service or replace with the new motor.
2.if no supply is comin to the motor terminla then ther is a problem with the wires.the wire is damaged so no power goes to the motor.
3.if the voltmeter/multimeter reads less reading then the problem is with the battery.the charge is not sufficient enough to start the motor. please recharge or replace the battery if required.
if my information was usefull please vote
Jun 26, 2010 | 1997 Volkswagen Golf
2002 jaguar x type wont start, lights, radio, air have power. clicking sound when turning the key to start the engine. Engine light stays, no engine turnover
Hi .
unlikely to be immobiliser fault ,so check basics,try a set of jump leads or check battery voltage above 12.5,if the clicking is coming from the starter motor with a fully charged battery then suspect starter motor failure.
Darren DCS
Jul 11, 2009 | 2002 Jaguar X-Type
Mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
May 09, 2009 | Light Outboard Motor Boat Bass Fishing...
1994 grand prix,motor wont start by key ,if i jump the starter it starts and runs for about 5 sec.security stays on for about 5 mins. then goes out still wont start
This is likely caused by a burned out alternator, charge the battery, verify it will hold a charge and replace the alternator.
Dec 08, 2008 | Pontiac Grand Prix Cars & Trucks
Umax Astra 3400 Flatbed Scanner Logo
Top Umax Office Equipment & Supplies Experts
Ricky Ostrom
Ricky Ostrom
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
