Question about Sony KV-32S26 32" TV
No Picture I recently moved from one residence to another.  After the move, I turned on the TV and received sound, but no picture (black screen).
  • Anonymous Dec 20, 2007
    Sony kv32v40 set comes on with pix. and sound, after about 2 to 3 min.
    pix goes black. sound ok and have hi voltage, and pix tube filaments.
    Genius:
  • 1,153 Answers
Tuner problems, to check use the Inputs A/V 1,2 or 3 If there is a picture then your tuner needs changing
Posted on Dec 03, 2007
I have an 1yo insignia roku tv and just got a new spectrum digital receiver/dvr. About 3 out of 5 times I get a black screen with volume. I have to turn the tv off and back to get a picture
Sounds like a problem with the T-Con board. Perhaps not to serious. Has the TV been moved or knocked recently before the fault appeared? If so it could be a bad soldering joint or loose connection to the T-Con board.
Jun 22, 2018 | Insignia Televison & Video
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
TV Has Sound but no picture
Change or move yellow one, of the cables, or component. if not then something you need from expert..
Dec 31, 2009 | Polaroid TDX-02610B LCD TV
SATELLITE DISH
Sure you can, if you have Dish Network go to the receiver and turn the TV and receiver on. Then press menu-6-1-1. This takes you to the point dish screen. You will come out with better results using a compass to find the azimuth the dish should be pointed toward and bore sighting the dish by pointing it in that direction. You then will need to move the dish in very minute increments pausing for 15 to 20 seconds after each move to ensure the satellite signal can be found. If you have ran a check switch prior to this and have lost all satellites you more than likely will not receive a signal until you run another check switch and have found the signal of at least one of the orbitals. If this proves to be to tedious and many times it will you can usually find an inexpensive signal pointing device at a store like Radio Shack. Hope this is some assistance to you. Let me know if I can be of additional assistance and thank you for using Fix Ya.
Oct 07, 2008 | Televison & Video
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Why does screen suddenly go black
Could be a loos wire in the casing for the screen. if this happens while moveing this is most likely. if you are stationary then it could be a power fault because the power feed for sound and the power feed for picture are from two different sources.
Mar 28, 2008 | Sony XM-475GSX Car Audio Amplifier
No Picture
check the power cord
Dec 17, 2007 | Sony KV-32S42 32" TV
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
The TV is only showing half of the picture
Hi Bigtate,
There is not much for me to go on with your description but here goes,
I suppose you have a convential TV set with a glass picture tube and not one of the new types with the large screen slim style displays!!!
If it a glass type picture tube then the following assumptions are made.
I hope yopu have not shifted house recently and moved the TV around???
If you have its possible the Yoke (its a device on the neck of the Picture tube that controls magnetically the scanning dot) may have moved and only is letting you see half a picture...
This is a long shot but it could be the cause..
Now the picture is supplied to you by a fast moving dot of light (Black & White set) that scans from the top of the picture and moves very fast down to the bottom of the screen, then flys back to the top of the screen and starts all over again during this process the dot lights up the picture tube to provide you with
the picture you see... (On a colour set there are three dots)
Its quite a complex process and its all controlled by electronics inside the TV receiver.
If you are getting only half a picture then something is causing the dot to only turn on for the lower half of the picture during its write time to the glass screen,
You dont say if the half thats off is white or black, so there are many things that the service technician needs to know before even starting to look for this fault. During the dot doing its write cycle down the sceen, when it reachs the bottom and flys back to the top of the screen it receives a synchronous pulse from the TV station, and this TV signal is critical in making sure you see the same picture as is being sent from the TV station.
Sometimes this sync pulse from the TV station is very weak and so your picture may float up and down the screen trying to lock to the incoming signal.. this just may be your fault.. but you dont say if the half of the picture that you see is floating or not..
Your situation may be that your TV has partially locked to the station signal and your aerial may be problematic,
but then you dont say if its on just the one channel or all of your station channels. So there needs to be more analysis of your situation prior to a positive answer being provided....
Sorry I can be of more help...
From YUBEUT...
Nov 10, 2007 | GE 31GT660 TV
Sony KV-32S26 32" TV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
