Samsung HLN617W 61 in. Rear Projection HDTV Television
Problem for Samsung HLN617W 61 in. Rear Projection HDTV Television
Samsung HLP5674 color wheel problem
By tkilberg on Aug 23, 2009
I replaced the color wheel that had two dislodged colored pieces. But the tv makes the same humming after the startup chime as it did before the last one failed, and the new color wheel only spins slowly (visible after removing bulb enclosure). Three cycles of the same thing and the tv shuts down. The ballast emits the usual usual click as always upon powering on, so I don't think that's the problem based on what I've read. Could the old color wheel have damaged any electronics when it failed? I have removed and reinstalled the new color wheel and it spins freely. Thanks for any insight you can provide.
Best Solution
posted on Sep 17, 2009
Very Helpful)
erics740
Rank: Apprentice
Rating: 100%, 1 votes
If you didn't replace the whole assembly with the color wheel, the sensor on the bracket could have been damaged. The sensor detects the black stripe on the hub assembly of the wheel to sense if it is spinning before lighting the lamp. I learned the hard way and just replaced the color wheel. 8 months later the sensor started failing intermittently and then outright failed and it had me scratching my head for a week trying to figure it out. At first the lamp would light for about 5-10 mins, good picture, and then would go out and all 3 LEDS on the front of the TV would flash. Had to pull plug from wall to get it to restart and the the same thing. After a while it failed altogether and the tv would try to start and shut down. It would restart by itself 2 more times, but the RPMs on the color wheel were way too high...the sensor was trying to read the RPMs and couldn't get a reading. The wheel was ramping up and down. After 3 tries, the tv would shut down with 3 LEDs on the front panel. I replaced the bracket with a new one (new sensor and wire) and all is well. I could not find just the bracket/sensor assembly, had to buy the whole assembly (wheel/bracket/sensor). Hope this helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung HLN617W 61 in. Rear
Questions and Unsolved Problems for Samsung HLN617W 61 in. Rear
Do you recommend Samsung HLN617W 61 in. Rear Projection HDTV Television?
Answer
Answer
brand new samsung lcd....flashing red light. flashes twice and won't turn on.
Answer
Samsung HLN617W 61 in. Rear Projection HDTV. Left side of screen has 4 inch section from top to... (More)
Answer
It is powering itself off.. It will turn back on ,but turns off again in a few minutes
Answer
have a 63" dlp model HLN617W and its making a grinding noise it turns on then shuts itself off... (More)
Answer
samsung flat screen keeps turning off...sound stays on...what is the problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
