Nikon 9x25 Travelite V Binoculars
Problem for Nikon 9x25 Travelite V Binoculars
Tasco OS36 Binoculars battery replacement
By DickV on Dec 03, 2007
The red light in the compass of my Tasco OS36 does not turn on when I push the button on the top of the housing. I am assuming that it needs a new battery but when I unscrew what appears to be the battery compartment on the housing there is a screw shaft on the underside of the "cap" which penetrates the center of a white plastic disc and fastens into the housing underneath this disc. The disc does not appear to be easily removed. I cannot identify any other fitting which would be the battery compartment. How do I get the light to turn on?
Same Problem
Jan 25, 2009
-   Can anybody let know precisely how to replace the battery? Solution described earlier in this forum is not much of a help. Who can help to solve this?-   frawar
Feb 21, 2008
-   Same problem as already posted-can't figure out how to replace the batts. The screw comes out, but only no place to put the batts.
HELP!!!!!! Jack-   alcjack
Best Solution
posted on Feb 20, 2008
Very Helpful)
jimwrey
Rank: Apprentice
Rating: 100%, 6 votes
Install a pair or LR43 batteries with the + sign up.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 01, 2009
Very Helpful)
Zeiss Man
Rank: Guru
Rating: 93%, 31 votes
The battery compartment is on the front of the binoculars next to the large lens (objective). It takes 2 batteries + side up as mentioned either
LR 43 or number 186 alkaline or silver oxide number 389 or SR54.
Be careful as there is a small metal clip holding them in place.
You can go to Tascos website and download the intruction manual. It is the same for the OS36 and OS54.
Was this helpful?
Yes
No
Solution #3
posted on Mar 13, 2009
Very Helpful)
fensantafe
Rank: Apprentice
Rating: 100%, 2 votes
The screw you removed holds the battery cover in place. The cover is roughly rectangular with rounded corners. Once the screw is out, gently insert a sharp blade into the hairline crack between the cover and the binocular body and pry the cover off. The two watch batteries will be obvious.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Nikon 9x25 Travelite V
Questions and Unsolved Problems for Nikon 9x25 Travelite V
Do you recommend Nikon 9x25 Travelite V Binoculars?
Answer
Answer
merch source LLC is a scam operation, they do not even have a website, and zero customer support.... (More)
Answer
when starting it up and you engage it to stabilizing it it go's down and does not stabilize and then... (More)
Answer
vintage binoculars by carl zeiss from germany serial number is 4367000 not sure of the age please... (More)
Answer
Where in Canada posibly Calgary can I purchase missing eyecap cover for the Nikon 9x25 Travelite V... (More)
Answer
I have unfortunately lost the R hand side rubber section that you put to your eye (Right side as if... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Binoculars Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
