Question about Nokia HS-23 Headset
Please help me with a diagram for hs-23 plug connections...
I have a repair center of my own in our vacinity..i deal repairs for hs-23 and other handsfree on a regular basis..i get managed with others..but repairing a stereo handsfree is impossible yet for me....i just need a coircuit diagram of hs-23..in which special description is given for plug connection...i mean that each wire color and pin number should be explained...dears it is really a problem for me
  • 1 more comment
  • ferozkb Dec 04, 2007
    well thanks man. it was so kind of u..but i think i found no diagram of my requirement....i try looking more
  • Papu bhai Jan 09, 2008
    I need a HS-23 diagram
  • syed_junaid Aug 07, 2008
    colour code
    Sergeant:
    Champion:
  • 270 Answers
Http://free-zg.htnet.hr/GoranJurkovic/nokia/
http://cellphones.hackaday.com/2005/08/16/how-to-make-a-nokia-pop-port-to-female-mini-jack-with-volume/
Posted on Dec 03, 2007
I want repair my HS-23 headset. But I haven't that's wiring diagram.
Posted on Oct 01, 2008
Please help me with a diagram for hs-23 plug...
Posted on Sep 09, 2008
The truth is mine's broken too. Right now I'm putting mine back together. I only found one image with the correct connections. Hope it helps...
Link: http://forum.mobiset.ru/files/thumbs/t_hs-23_880.jpg
Posted on Nov 02, 2008
Hi, I took my headphones (DT 770) to have a new jack put on after the old one was damaged and i (stupidly) cut it off. They are unsure of the wiring configuration and the technical info regarding the...
Hey benblay7. Cutting the wire was not stupid at all.
Two of the wires are ground and are tied together and soldered to the ground terminal. These should be the same color, usually a shiny copper color. The ground is negative. The tip of the plug should be wired to the left side and the center is, of course, the right.
Check this out: explainthatstuff.com/howtorepairheadphones.html
Good luck from Detroit, MI.
Apr 29, 2011 | Beyerdynamic DT 770 PRO Professional...
Nokia HS-20 AD-41 broken who can repair please help me with a diagram
If the wires are open or the connections are visibly broken then the connections can be mended. But if there is fault in the earpieces then I suggest that cost a new one must be checked before you think of getting this repaired.
Mar 14, 2011 | Nokia Music Headset HS-20 & AD-41 Headset
I need a drawing of a carburettor on a 61 Huaqarrna chain saw\r\nwhere do I get it? It is a husqvarna Chain saw
You didn't specify of its a 61 or a 61 Rancher. Here's the info you need to take to your Husky dealer. The diagram will be with the major repair kit.
Model 61, then the 61 Rancher:
CARBURETOR Model 61: ecblank.gif Tillotson HS-163A, B , HS-254A series or
Walbro WS series
MAJOR REPAIR KIT: ecblank.gif RK-23HS for HS-163A MINOR REPAIR KIT: ecblank.gif DG-5HS/T for HS-163A
CARBURETOR Model 61 Rancher: ecblank.gif Tillotson HS-163A series or
Walbro WS-17A, B series
K10-WS
D10-WS
May 18, 2010 | Husqvarna Garden
Hs 1200connect to xbox360
there are series of problem in xbox which can be solved without much technical knowledge your problem is one amoung that ........ your problem belong to that so dont worry i will give you the link to download the repair guide that will help you a lot Click Here
Jan 20, 2010 | Creative Technology HS-1200 Wireless...
What # fuse is the chmsl on a 99 cherokee
The Center High Mounted Stop Light work directly with the Brake Light system, so, review the Rear Lightning (Fuses 6, 23 and 27)
- WJ Repair Manual Section-08L-Lamps-Ewj8l (page 10, fig. 4)
- WJ Repair Manual Section-08w-Wiring-Diagrams-ewj8w
I hope help you. Good luck.
Sep 08, 2009 | 1999 Jeep Cherokee
Sony DCR-TRV19 Problem: None of the functions except cassette ejection will work. Error Code:C:31:23
Error code 31:23 shows problem in Take-up Reel section of your Sony Camera. If you know about camera repair, please check Take-up Reel section in tape mechanism and if you don't know, please contact nearest Sony Service Center for proper repair.
Aug 17, 2008 | Cameras
HS-23 problem disconnected
Assuming that the joint which connects the neck strap has been damaged ( see below image )
, I advice you fix the loosed or broken joint back in its proper place permanently by using fevi kwik or some other fast bonding adhesive, but the only problem which will remain is that each time you have to use the headset you will have to wear it through your head andremove it the same way.
Apr 19, 2008 | Nokia HS-23 Headset
HS-23 Not Being Recognized by Phone
Rub the pins of your headset, and your phone with some tissue paper or something like that.
You might use some cleansining agent like alcohol.
Switch off your phone while doing that.
I too encounter such problems.
Dec 01, 2007 | Nokia HS-23 Headset
HS-23 Nokia Headset
hey kev.. all i can ask you is ... the following 1) open the ear piece of the non working .. then take a multimeter (keep meter in resistance mode) and check the resitance if its good it will show you.. apx 32 0hm and if its showing you 0 or .1 or below 16 ohms.. 2) after you disconnect the speaker.. the broken one that is... chek the cable connectivity.. or rather continuity.. for this keep the meter in continuity mode the pervious resistance mode.. then take one wire and connect one prob from meter to it.. and take the other prob and connect ti too the pins of the cnnector.. ( here is there are 4 pins dedicated to the ear phone.. 2 for each.. nd they are towards the end sid.. just below the # key.. frm # key the last 4 pins connectors are for audio.. ) check the.. pins on the cord connector not the phone.. i hope you can find what wrong with your... head set now.. and yeah if the speaker is out jsut replace both the ear piece with sony or aiwa earphones.. it wil work best if your cable is gone then all the best buy a new one tc aditya
Aug 04, 2007 | Nokia HS-23 Headset
Nokia HS-23 Headset Logo
3,758 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
