Question about Samsung SyncMaster 213 T 21.3" LCD Monitor
Red Line I have a Vizio 42" plasma tv removed it from the cable box recently and now have a cable wire only to the TV. Last week tuern on TV and a Fed Vertical line appear on the left side. THis happen just after my daughter finished watching a DVD. Can I fix?
antiochpc
  • 1314 Answers
SOURCE: Red Line
I was just looking at Samsung's site regarding this issue. It is most likely a line of dead pixels. Direct from their site: "The thin red, green, blue, white, black, or yellow line you see running through your LCD monitor is most likely a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced. To set up a service appointment, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your monitor's model number and serial number on hand when you call." http://erms.samsungusa.com/customer/sea/jsp/faqs/faqs_view.jsp?PG_ID=1&AT_ID=15336&PROD_SUB_ID=28&PROD_ID=-1
Posted on Jun 21, 2007
SOURCE: SyncMaster 920n Monitor 1 1/2" greeen colour vertical bar
this discoloration problem occurs commonly in every1 s pc ... this problem occurs due to the nearby magnetic field emitting appliances just like speakers... so what u have to do is u must keep some gap with the speakers from the monitors & after that press menu button on ur monitor and give degauss.... this will solve your problem....
Posted on Feb 06, 2008
SOURCE: green line vertical on screen keeps appearing
in the monitor menu button you will be having a option called "degauss" give that when it appears ...
if you still persist the same problem then there may be some problem in the CRT tube ....
just take your monitor to the technician ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Posted on Aug 12, 2008
mithunsree
  • 32 Answers
SOURCE: vertical red line 5cm in from the rigth side
problem in video section
Posted on Aug 11, 2009
  • 406 Answers
SOURCE: Two vertical 1'' white lines on right side of Lcd panel
If the lines are parmanent, Then suspected part is LCD Panel.
Posted on Dec 30, 2009
Red lin appeared on my vizio tv and now its not
is this dead set? if no power at all check first ac cord for the ac line from wall socket going to tv power ckt. or else we need to open back cover.
Mar 31, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
I've a Panasonic 42' Plasma tv purchased recently and when I connect my Comcast DVR box via Composite A/V connection, I see only black n white images..
Be sure the 3 video wires are color matched on both ends. Try a different cable. Connect another device like dvd player to that same Component input if it's ok then cable box is the problem. If still B/W then replaced a/v or main board.
Nov 23, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Hello, Currently I have Vaio laptop connected to my Vizio 42" inch flat screen TV. There's no audio coming from my Vizio TV. So I connected an audio cable connected to the stereo jack. Where do I connect...
You need a 1/8 in cord on both ends. Normally, its an 1/8 inch audio connection in your tv to work with PC (the same connection as when you plug it in your comp) So u would need a wire that both ends are 1/8 inch (Headphone jack sized)
Sep 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Connect home theater to tv
Do you have the cables connected to line out on tv ? Do you have the correct source and audio type selected in the home theater (analog/digital/coaxial).
Jan 18, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
Connection for tv cable to hitachi 42" plasma Tv
there is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
Dec 07, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Red line on screen
Hope this makes sense.
Sep 29, 2007 | LG 50PX4DR 50 in. Plasma TV
Samsung SyncMaster 213 T 21.3" LCD Monitor Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
