FixYa.com
Tags:
RCA RTD120 System
Picture is in black and white
posted by moog on Dec 03, 2007
we just moved and i just wired everything up and it is all working perfect except our picture is in black and white. i know there is an easy fix for this problem because it happened a couple times before because i pressed the wrong button or something. Yikes!!! moving makes a person NUTS!!! Would appreciate help!
Comment by moog, posted on Feb 07, 2008
took too long to get the solution. fixed it myself
thank you
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 05, 2008
Thanks for Trying (70)
TecniklyNuts
Rank:Wiz Wiz
Rating: 82%, 54 votes
If you are using the component video inputs, check your component video connections. You may have the Pb and Pr connections reversed or not plugged in at all. All three (Y,Pb, and Pr) are needed for it to work right. Also make sure that you have the component cables from the home theatre going to the component inputs on the TV. You can get the manual at the link below if you need it.
http://support.rca.com/main.html?pagetypeid=6&topicid=307&selectedmodel=RTD120&navtypeid=2&selectedFamily=video&prevPageIndex=2
Hope this helps, and please rate my advice, good OR bad.
Good luck!!
Rating Locked! (?) moog has rated this solution as Thanks for Trying
Can you Help with these Home Theater Systems problems?
RCA RTD120 System
RCA Home Theatre
After about 20 hours of use my... Answer This...
RCA RTD120 System
remote
Changed batteries in remote,... Answer This...
RCA RTD120 System
Surround sound setup
I can't get to the menu to set... Answer This...
RCA RTD120 System
No voices
I can only hear background... Answer This...
RCA RTD120 System
rca rtd120 not turning on
when i turn off my rca system... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
