U-Line 75R Refrigerator
Problem for U-Line 75R Refrigerator
U-Line outdoor frig not cooling properly
By b_gray on Aug 22, 2009
I have a u-line ice maker/frig which I keep outdoors. The frig temp is between 60 and 70 degrees. It appears to make ice but may have slowed down the last day. I checked the seal and it appears to be on and definetely not cracked. Any help would be appreciated, thank you.
Solution #1
posted on Aug 23, 2009
Not Rated)
garing
Rank: Wiz
Rating: 82%, 352 votes
check timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32 don't damage coils
Was this helpful?
Yes
No
Popular Solutions for U-Line 75R Refrigerator
Questions and Unsolved Problems for U-Line 75R Refrigerator
Do you recommend U-Line 75R Refrigerator?
Answer
Answer
I have a U-Line 75 Bev and need to replace the temperature control but cannot find the correct part... (More)
Answer
I had a flash of light and electrical smell from my bar area, I moved the fridge to ck outlet,... (More)
Answer
the norcold in my motor home works fine on propane, but not on ac or dc! could it be the heating... (More)
Answer
There is a small ledge container on the back wall of the fridge which extends across almost the full... (More)
Answer
gss22 ifre ge refrigerator,Have new part but it is a replacement to original wiring is not the same.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
