Question about Sony PlayStation 2 (PS2) Console
After playing ps2 for about 30 minutes it locks up and you can only see a still screen, it doesn't do it with all games only some
Ps2 problems
  • 709 Answers
It could be a couple of things. Most likely being that your disc is scratched, and everytime about 30 minutes into the vdeo game or Movie, your system cannot read the data and just stops finctioning. Try a different disc to see if it locks up on it at the same timing.
The other thing that may be aggrevating your Console and causing it to lock is dust and lint build up. If the dust and lint bloack the heat from getting out it will lock up on you say after 30 minutes or less. open your case and clean all the dust and lint out.
Posted on Dec 03, 2007
Acer aspire 9300 notebook black screen while playing a game
The way you describe the problem , it sounds like your graphics card went bye bye .
Jan 15, 2018 | Acer Aspire 9300 Notebook
Playing MLB the Show on PS3. Game loads fine, franchise I've been playing loads fine. But once I try to play a game, bar starts as game loads then game cuts off and goes to main PS3 screen.
Is your CD dirty or does it have any cracks? It might just be the problem. Otherwise, it could be corrupt game data. Clean the disc, if it still doesn't work I'd try deleting the game utility data and re-downloading it. Hope this helps in some way or another.
Apr 19, 2012 | Sony Playstation 3 (PS3) Console
XBOX 360 disk drive
Happens to my old Xbox 360. Unplug the power cord from the wall and leave it overnight, then plug back in in the morning and see if it works. (If it doesn’t unplug again this time only for 5 minutes )
Dec 14, 2017 | Microsoft Xbox 360 Console
One game will play then the others say check owner manuel and wont play
  1. Some games may need to be cleaned. Clean each disc with a soft, slightly damp cotton cloth (use water only). Clean them from center towards the edges; do not use a circular motion. DO NOT use paper. Once they are cleaned, dry the disc using a dry portion of the cloth and wiping in the same style as you did to clean the discs. After all of the water is gone, let the discs sit for at least two minutes to completely dry before inserting any of them into the Nintendo GameCube.
  2. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  3. Ensure the games are being loaded properly. With the power turned off on the system, replace a Game Disc (printed side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen. Try this with a few of your games.
If Troubleshooting doesn't fix the problem, and it is happening with all your games, then your system will need repair. Check out our convenient repair options.
Feb 23, 2011 | Nintendo GameCube Console
It takes about 20 minutes to get the disc to play.
Jan 15, 2011 | Nintendo GameCube Console
Reads no disc or see instruction manual every time you turn it on
  • No Game Disc:
    This error can occur when the Game Disc has been removed while the system is on and then the Disc Cover is closed. Follow these troubleshooting steps:
    1. Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
    2. Determine if this happens with more than one game by inserting a different game into the system.
    If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
    If the error occurs with only one game, follow the individual game disc troubleshooting.
  • Troubleshooting - Multiple Discs
  • Jan 09, 2011 | Nintendo GameCube Console
    The disc in the game cube does not turn. the error say, game disc cannot be read.
    The Disc could not be read:
    Single Disc
    The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
    Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
    1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
    2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
    3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory
    Nov 28, 2010 | Nintendo GameCube Console
    Was playing Super Smash Brothers, played 1 5 stock 1v1v1v1 against 3 computers, then went and started a second round. It lasted for about a minute or 2 and then it locked up... i hit the reset button, and...
    Well I think that the expansion pack has died I had a problem while I was in the middle of perfect dark it would freeze and then 2 seconds later the screen went black and than it went to the tv screen saying no signal. the expansion packs make it look like it died but it didn't.
    Nov 01, 2010 | Nintendo 64 Console
    My gamecube messed up after trying to do a glitch on metroid prime i saw on youtube and it worked but when i went to save the gamecube make A click noise and then the black screen of death appeared saying...
    Wait it could or might just be karma then. Never put cheat devices in your video game consoles because it can corrupt the system and mess up the console too. Play the games fair and square like I do because they still work and the machine doesn't want people to cheat either thats why.
    Oct 01, 2010 | Nintendo GameCube Console
    PS2 Console Problem
    My ps2 actually did this for a long time. Either it "Died" as they say, or something is wrong with the internal part of the ps2. If you open it properly, there is a white gear you'll find. This keeps the cd, and a few other things on track. Turn this gear to the left 3-5 ticks. Close the ps2 and it should be fixed. If you have anymore problems post it please.
    Nov 29, 2007 | Sony PlayStation 2 (PS2) Console
    Sony PlayStation 2 (PS2) Console Logo
    26 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
