Question about Kenmore 22422 Top Load Washer
I can't get the timer switch off
I have a Kenmore Washing Machine (mod. # 110.20642990) and I can't get the switch off to replace timer unit. I have tried to turn it counter clockwise when it is pulled out and pushed in, but nothing works.
  • jjevans30 Dec 04, 2007
    I got the knob off, but now I can't get the timer to disconnect. I unplugged the wires and removed two screws.
On the inside of the timer switch hold the shaft that the Knob is on with a pair of needle nose pliers and pull the knob from the front. " Gently"
Posted on Jan 24, 2008
Kenmore washer does not fill first ,goes right into washing.Replaced timer ,same problem.
Hello Sue,
The reason your washer starts agitating instead of filling first is shortted water level sensor switch that should be replaced.
The part number for that switch is W10177795
GENE
Nov 11, 2011 | Kenmore Washing Machines
I have a kenmore model M22922 washing machine that has stopped working when it gets to the spin cysle. I replaced the timer switch, but that did not help
You replaced the wrong part.
The lid switch must be replaced.
If we had a complete model number from the machine we could be more specific.
Aug 28, 2010 | Kenmore Washing Machines
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Sep 12, 2009 | Kenmore Washing Machines
Washing machine is Kenmore mod. 110 22422100. After setting load size and time setting I pull the dial and sometimes(most of the time) water won't fill and the agitator will agitate. What is the problem...
You have a broken point inside the timer. I hate to say that there is no cheap solution. You will have to replace the timer. There is no rebuild kit or anything like that to repair the timer. I know of two suppliers where you can buy a replacement. I use these sometimes when I regular supplier hasn't got a part in stock. I checked the price at both for you and found the best price at www.appliancepartspro.com . their cost if $123.08 plus shipping. They ship same day if before 4:ooPM. Their Part Number: AP3020181 . When you go to their site enter either your model number or this part number. If you enter you model #, scroll down until you find the timer, Th part # will take you straight to it. I sure hope this helps.
Please rate solution
Sep 07, 2009 | Kenmore Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Washing problem
First, check for a bad lid switch. If that checks out good, check voltage at the motor. If you have voltage, replace the motor. If you don't, check your timer to see if voltage is leaving the timer.
Oct 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washing machine mod.# 11026842692
could be a broken 2nd rinse switch. contacts would not open up.
the noise could be coming from the gears inside the timer slipping.
if it is a kenmore, usually, it has these plastic cover on each side of the control panel. pry it slowly and lift it to exposed a screw that is holding the panel.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
104 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
