Question about Sony SDM-HS73P 17" LCD Monitor
URGENT Big project due...Monitor won't stay on...light goes yellow after initial message c below
No input signal going to powersave mode...than black screen and power light turns yellow, please help!
  • Rijihs Feb 06, 2008
    no input signal go to power save.
    monitor led gets yellow.
    black screen shows.
I checked cable lots of times. even i tried DVI-D connector but it is still same.
Posted on Feb 06, 2008
  • 983 Answers
Check the cable which connects from the monitor to cpu is connected properly... if it s not connected properly this problem occurs.. just reconnect it ... ur problem will be solved...
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously. in...
It usually depends on the monitor type and/or whether the monitor power cable is connected directly to the wall-socket or to the PC casing first. Both might explain the different behaviour. If they're all connected the same way, it's just the type of monitor that doesn't go into 'standby' mode automatically when there is no signal. You could post the exact make and model monitor and/or contact their customer support, but it's more likely not a configurable option ...
Oct 17, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
My desktop monitor direct go in power save please solve it as soon as possible its urgent
power save mode indicates no input signal. Check the input signal with a known good monitor. if the signal is good then dell monitor is faulty. Power cycle (unplug the power then plug it back in) the monitor to reset to factory and if it still goes directly into power save mode the unit is faulty.
May 01, 2011 | Dell E1709W Monitor
Turn monitor on and the light stays yellow will not turn green and screen stays black
When it lights up the yellow light instead of the green one, that means that the monitor is not getting a signal from the computer.
The things to try (from simplest to most complex) are:
  1. Make sure the computer is on and not in "sleep" mode -- press the "Caps Lock" key and see if it lights up the caps-lock light on the keyboard.
  2. Make sure the video cable is connected from the computer to the monitor (that the cable hasn't come loose on either end)
  3. If your monitor has multiple inputs, make sure it's set to the right (probably analog VGA or DVI) input
  4. If your computer has more than one video output (like a laptop with it's internal screen plus the external monitor) then make sure the external monitor is enabled
If none of those solve it, post a comment back here and we can dive in to the more complex tests
Sep 06, 2010 | Computers & Internet
LG1717S powersaving mode problem!
Have you tried to disable the pwer saving mode and see what happens. What operating system do you have on this laptop please ?
Mar 07, 2009 | Computers & Internet
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
If it's going into powersave mode, it usually means it's not getting a signal from the video card. Try plugging this monitor into another machine or laptop and you should be able to tell if that's the issue.
May 26, 2008 | Dell E171FP 17" Flat Panel LCD Monitor
On Pwr up logo appears then LCD returns to stanby Black screen
I will assume the monitor is staying on during the boot process all the way until Windows loads.
If that is the case, then...
  • Start the computer
  • wait until the initial bios/logo screens for your motherboard go away.
  • Press F8 to get the Windows recovery boot menu
  • If you see the Windows Logo you would normally see then press rest and try again.
  • In the recovery screen, select SAFE MODE
  • Boot into Windows and uninstall your video card.
  • Reboot the computer the normal way through the start menu.
  • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
Let me know how you go =)
Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
205 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
