Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
If it is showing a paper jam and you do not see it then you need to look for a small piece of paper that might have ripped and is stuck in one of the sensors.
yep it is common error for dp-180/190. and the usual cause of that are worn out 2 bushings of heat roller what you can do with that is to clean the fuser unit esp. the bushings of heat roller. well off course the safest way is to replace the whole fusing unit.
yep!
it seems that you are having a machine error. did you see also the prompt indicator shape of wrench?
if yes pls inform me i can assist you somewhat. :)
You might want to try to pull the drum out and reinstall it... that just might do the trick. If that doesnt work try opening every door on the printer and then close them.
