Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic 47wx42f projection
On my 47wx42f projection hdtv cannot align colors just went out all of a sudden tv about 4 yrs old
  • lincarlen Dec 03, 2007
    PT-53WX42F - I have the same problem. There are two convergence settings - the first gives you a huge cross hatch across the screen, but I can't get it lined up...the line stays wobbly so some parts of the screen give a red and green shadow.
    New Friend:
  • 12 Answers
I'll second the original fix recommendation. I just did this to a 47WX42F - I replaced the STK392-110 convergence ICs with STK392-150 parts. The STK392-150 is a higher rated part than the 110, so hopefully it should last a little longer. You should also make sure that none of the power resistors feeding to the Convergence ICs (they sit right in front of the ICs and are 2.2 Ohm parts) have burned or opened up...replace them, if damaged, too. None of mine were damaged, though. Other recommendation is to get Hitachi STK ICs, not a knock-off version.
Posted on Oct 08, 2008
    Problem Solver:
  • 5 Answers
Joe,
It sounds like your may need to replaced your convergence ic's loc# ic7001 and ic7002 stk392-110. That should take care of your alignment problem.
Posted on Dec 03, 2007
Picture suddenly went out and the lamp and temp lights in front circle are blinking.
Hi,If your tv is between 2-4 yrs most likely it's time to replace the lamp.If you hear continuous clicking it could be the ballast which is the board that powers the lamp.If you hear buzzing it could be the color wheel,which is a spinning wheel that creates the color on your tv.God bless you!
Oct 13, 2009 | Samsung HLN4365W 43" Rear Projection...
RED ARCH ON LEFT BOTTOM CORNER
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
you can get the two convergence ICs STK392-110 at the following link with free instructions with pictures so you can repair it yourself for around 50
heres the link.
http://servicemanuals.vstore.ca/
Aug 28, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic- 47wx42f
the convergence ic's are at fault need replacing,call a service shop and ask for estimate to repair .should be under $ 300.
Dec 09, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
164 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
