Question about Nikon Telephoto AF Micro Nikkor 60mm f/2.8D Macro Autofocus Lens
Error message My new lens was functioning fine but now a ERR display and the lens will not function, any ideas?
  • cypridiot Dec 03, 2007
    Hi, Forgot to state,
    the malfunctioning lens that creats the ERR message is a
    The other lenses work fine.
  • Anonymous Mar 31, 2014
    Lens will not stay open? I thought it was a battery problem, but have installed NEW batteries???still no luck. When I try to hold lens out on initial power up..it gives me a lens error message?!? Can anyone help??
  • 667 Answers
You might want to check the position of the aperture ring on the lens. If it is not set at the highest number, ( IE smallest aperture, f22,f32 ), then the camera will display that error message
Posted on Dec 23, 2007
E000719-0031 error code for canon ir c5250
E719 0031 00 Title Error in serial communication at the start of the New Card
Reader
Description Failure in communication with the serial New Card
Reader at start-up.
Remedy - Check if the cable of the serial New Card Reader is
disconnected.
- Take out the serial New Card Reader.
- COPIER > Function > CLEAR > CARD
- COPIER > Function > CLEAR > ERR
Dec 20, 2013 | Canon Office Equipment & Supplies
I am recieving a error 1 message on my Canon RebelXT/Eos
ERR 01 is a lens communication error. Try cleaning the contacts on the lens and in the mirror box.
ERR 05 is a flash error. It is usually caused because the flash failed to pop up. This can be casued by something as simple as the flash hitting the brim of a 'gimme' cap or impact to the flash or most likely spillage of sticky liquid around the flash and its pivots.
The XT also is notorious for having the bottom right screw of the rear circuit board come loose and short out some function of the camera, or even blow the main fuse or damage the circuit boards.
Jul 12, 2012 | Canon Rebel XT / EOS 350D Digital Camera
My cannon iR3320 displays error code E000002-0000. the problem started today after yesterday's power surge
Most likely an error reset will take care of the problem. Get into service mode by pressing the additional function key, 2 & 8 key at the same time, then additional function key again. Press copier, function ( at top of display ), CLEAR, ERR then OK. Power down and back up again the copier. If error continues then the fixing film assembly will have to be replaced.
Dec 08, 2010 | Canon imageRUNNER 2200
Graphing Feature error message
This usually happens after the statistical graphs have been used. You should deactivate them. Press [2nd][Y=] (STAT PLOT). Select [4:PlotsOff] [ENTER]. Calculator echoes Done on main screen.
Restart your graphs.
Dec 28, 2009 | Texas Instruments TI-83 Plus Calculator
Error message
the fixing unit is faulty.to clear the error do the following
press additionel function button and press2and8 at once and press additionel function button.select COPIER>FUNCTION>CLEAR>ERR.
Jul 27, 2008 | Canon imageRUNNER 2270 Copier
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Hard Disk error
power up your dvd then you you disconnect from the power cord.wait a few mins like 5 mins then you plug it in back and power it up if that does not corect your problem.the strip that leads to your dvd lens needs to be changed.or the micro chip that controls the hd needs to be changed.however take it to a tech.
Feb 19, 2007 | Pioneer DVR630H DVD Recorder
Nikon Telephoto AF Micro Nikkor 60mm f/2.8D Macro Autofocus Lens Logo
185 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
