Question about LG DLG5932W Gas Dryer
LG DLG 3788W not heating
My LG dryer is not heating it is a gas dryer So I am wondering what to do. It turns fine all lights come on. Even when I use manual mode it does not fire up. Is there a place I have looked in vain to try to find anything on LG manuals for repair...
  • 1 more comment
  • Anonymous Dec 04, 2007
    yes can anyone help
  • thomas68 Dec 06, 2007
    Thankyou I have searched high and low for the specs etc. now I have an idea and a accurate way do troubleshoot the problem thankyou soooo much
  • Anonymous Jan 01, 2008
    Thomas68,
    Did you solve your gas dryer issue of no heat? If so, what was the solution.
    Pkedz
Can you look in one of the holes in the back and see if the inside glows orange after you turn it on? If it doesn't could be the igniter, if it does glow orange, clicks or clacks, and glows again 20-30 seconds later, click/clack and nothing, it's probably the gas valve. I'm going through the same thing with a new one and they had to order the valve and a new controller board in case it is bad too. If you are handy, have an electronic tester, and have the patience, go to http://136.166.4.200/contents/Laundry/DLG3788.htm for the service manual and disassembly instructions and see if you want to tackle the test flow for no heat. I just stumbled on the site.
Posted on Dec 05, 2007
DLG 3788W Dryer
could be the drum wheels
May 04, 2013 | LG Dryers
My LG gas dryer model DLG 2555W runs but produces no heat
Gas out. That is the problem. Refill Gas.
Aug 11, 2012 | Cell Phones
My dryer doesn't seem to function properly, it's just blowing cold air. I had it on for over one hour, my clothes are still wet and the air is still cold. The dryer model is LG Tromm DLG 3788W. The...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 24, 2010 | LG Dryers
LG DLG 2526W dryer running but no heat
heatman101
May 22, 2010 | LG D2526 Gas Dryer
Lg dlg 7188rm gas dryer will not heat
Check to make sure that the thermal fuse is not blown. Small plastic piece with 2 wires coming off of it. Typically this is problem.
Feb 01, 2010 | LG DLG7188 Gas Dryer
LG DLG8388WM won't heat ...
It could be a clog in the supply pipes inside the dryer itself or a faulty regulator your best bet it to find a local repair shop as dealing with any gas appliance without proper knowledge can destroy your appliance or worse you PS: do you smell gas when it runs if so then it could be the igniter is faulty!
Nov 13, 2009 | LG DLG8388 Dryer
Dlg 3788w-7.3 cu ft gas dryer
You don't, it is gas dryer, so I advise you to get a authorized gas technician to look at your unit.
Chances are the blower assembly is out of whack, maybe the motor is off its brackets.
Sgt 48
May 23, 2008 | LG DLG5988 Stainless Steel Gas Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
LG DLG5932W Gas Dryer Logo
448 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
