Question about Maytag MER6772 Gemini Electric Kitchen Range
Problem w/burners & lights after self clean
Purchased in 2001, first time with a problem. Ran a self clean on top oven with no problems. Both ovens work, oven lights work, keep warm burner works and red light on panel goes on when keep warm burner is turned on.. Left two burners work. Right two burners (including inner and outer elements of large fron burner) do not work. Panel lights for all four burners do not work. Hot surface warning lights do not work. Followed reset features to restore factory defaults in case that was an issue, turned off breaker to stove for several minutes and turned backed on in case that was an issue.
  • 22 Answers
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Posted on Dec 04, 2007
SOURCE:
After running the self-clean feature on my 21 year old Beaumark stove all of the indicator lights (oven, burners)are not working. The clock (not digital) is not working either. Oven and burners are still...
you may have a temp thermo on the back or the top of oven . hi tempt would have shut off electrical . should have shut the oven off also / wiring in top may be faulty. now if the top burners are working but the clock & oven are not then you have a saftey thermo out . you may need to repl with new one . some ary resetable. take the old one to a appliance parts co . so they can read the tempt,s on it ,. should be able to match .. mm
Nov 20, 2009 | Cooktops
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
I have an older GE self-cleaning oven. It has an
Latch may have been damaged from heat of self clean. lift top where burners are, should see cover over latch assy(turn power off to unit) remove screws for cover and should be able to free latch.
Jun 08, 2009 | GE 30" Self-Cleaning Freestanding Electric...
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Ran auto clean for oven and cleaned stove top, not auto lighting
One. DO not use self clean on ranges unless you want to replace parts.
Two. Replace the thermal overload fuse.
Three. The manual should be in the console head.
Feb 22, 2009 | Kenmore Kitchen Ranges
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
291 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
