Question about Compaq Easy Access Internet Keyboard
Keyboard misbehaving during online game play
During online play,holding down a key for play functions caused a beep warning and gets stuck going in one direction
0 characters
1 Points
I am trying to find out what the blue symbols on the function keys of my sk 9020 keyboard stand for
The blue keys serve as a secondary function for your volume control, monitor controls and pause play fast forward rewind (in media mode). In order to use the blue keys that are numbered from F1 to F12, you must depress and hold the Fn key that is located at the bottom left side of the keyboard. Here is a way to test it: Open up any file that plays sound for longer than 1 minute (60 seconds). While this file is playing, hold down the Fn key and simultaneously press F8 and listen to the volume get louder or Fn and F7 together and listen to the sound get lower. The picture of the crescent moon F1 will adjust the brightness of your screen. F2 will magnify your screen. F3 will take you to your email. F4 will take you to your internet home page. F6 will mute the volume. F7 will lower the volume. F8 will raise the volume. F9 will rewind your video playing. F10 will stop the video. F11 will pause or play the video. F12 will fast forward the video.
Mar 06, 2012 | Gateway (7001434) Keyboard
Instead of getting the @ symbol when I press shift +2 i get "
you need to hold down ctrl and function on the left side of your keyboard, and then hit the shift key on the right side of your keyboard. Then let go of right shift while still holding down the control and function keys, and then hit right shift again.
these blue keys are french keys. if you change your keyboard settings to english US or UK, it will get rid of the blue functions, but for some reason, they tend to turn themslves back on again after time. Most likely due to automatic updates followed by an auto restart. Also, I find that the issue only arises if I am in my hotmail issue in Word docs.
Jan 13, 2010 | HP D8597A Keyboard
I have a notebook nec Lavie LF550 / 4 Japanese have. The problem 1. keyeboard not function properly, especially in numbers. 2. Inverse function .. caps lock on switch to lower case and vice versa. ... How...
Hold down the "Fn" key and the Press the F11 key or the corresponding F Key that says NumLk on it. The light should go off and all should be back to normal.
Oct 01, 2009 | Compaq Keyboard
Keyboard beeps when any key is pressed
The reason these beeps are happening is because there might be a key that is slightly depressed enough to where its registering keystrokes. Move your fingers all over the keyboard and see if you the beeps stop after you do that. If it still is going on then that means your keyboard is bad and will need to be replaced.
May 28, 2009 | Gateway 2520915 Keyboard
Keyboard restricting key combos
The beeping is indicating a keyboard error. If that combination worked before and the key combination in question worked earlier without an error? I would suggest reinstalling the game as possible file corruption may be at fault.
Feb 12, 2009 | Acer Keyboards & Mice
Keyboards Beeps and Freezes
How much memory do you have install in your computer? This may not be the problem but can cause the problem you have if you don't have enough memory installed.
Hope this helps. Bud
Apr 20, 2008 | Kensington PilotBoard 64379
Keyboard stuck in upper case
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
Keyboard problems
confime if the game is pirated or not. If it is then donot use it any more. If it was a free down load then,it should have finished with its life and may harm your system so discard the game.If it is licenced version of the game then approach the company for assistance and upgradation / advice.
Sep 01, 2007 | Logitech Cordless MX Duo 967300-0403...
I found out what was wrong in my case. Someone had tampered with the accessibility options
So for anyone with keyboard problem check :
In Windows XP : control panel-> accessibility options -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
In Windows Vista : Ease of access -> Ease of access center -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
Jun 25, 2007 | Gateway 2520915 Keyboard
Keys won't work while playing the games ..
Hi just try to reinstall the drivers from the cd if all ells fails take it back and get a replacment S ITS only a few weeks old i have the same system key board and this is some thing that has not happen to me
Jun 16, 2007 | Logitech Optical Keyboard & mouse...
Compaq Easy Access Internet Keyboard Logo
96 people viewed this question
Top Compaq Keyboards & Mice Experts
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Keyboard and Mice Expert? Answer questions, earn points and help others
