SOURCE: dishwasher will not drain water out
if plumbed in under the sink, check the spigot the drain hose goes to is not blocked - a common problem. if on drain you should be able to hear the drain pump working. if you hear a faint humming noise instead, then there is probably a foreign object stuck in pump. also check for blockage in the drain hose
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
SOURCE: Dishwasher will not drain (water just trickes out) fill is good
Drain valve not opening or pump impeller loose on shaft - is it washing ok?
My guess would be drain valve not opening. It is a 110v solenoid and they get stuck or burn up. New solenoid costs ~$20.00
SOURCE: kenmore dishwasher will not drain
check ur valve and clean it out possible blocked read ur Manuel for dishwasher and help tips
SOURCE: dishwasher not draining. full of water after
You will have to lay the dishwasher on its back to access the PUMP
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
