Question about Toshiba 20HLV16 20 in. LCD Television
What must I do to attach a Wall Mount to my Toshiba 20HLV16 LCD Chassis?
Need to attach the wall mount to the rear of my new TV/DVD. Do I remove the lifting handle and attach the mount there or what must I do to prepare my TV for hanging on the wall? I purchased an Omnimount 17FM-T Tilt LCD mount to use, as it was one of several recommended by the merchant I purchased the TV from. Thanks for the help!
Attach a wall mount, to back of a 32" sharp, LCD flat panel
Posted on Dec 09, 2008
Hi. I have an old Sony Wega 32" LCD TV which I
ok it depends on the wall mount but this is the basic idea of it. make sure there is at least one other person to help you.
1. Make sure everything is off and unplugged from the tv. 2. If you have cables holding your tv to the wall remove them. 3. there should be securing screws at both sides of the arms attaching the tv to the wall. loosen them/ remove them. 4. lift and pull the tv away from the wall. have a friend help you. 5. remove the screws and bolts from the tv and the wall mount and you should be done.
If this doesn't work, find the manual for the wall mount. if you need help or additional tips put them in the comments. Thanks
May 26, 2011 | Sony Televison & Video
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
I have a 37
Metric M5 screws, the wall you buy will be supplying with mounting hardware.
http://www.toptvmounts.com/
http://www.mountsdirect.com/
http://www.mountsmadesimple.com/
Just Google " wall mount for xxxxx"
Nov 24, 2009 | Televison & Video
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
Can i wall mount this
Usually, UMC include the screws already screwed into the wall mounting holes that you should use to attach a wall bracket. This is so you dont then go and use longer screws often supplied with wall mounts that are way too long and can damage the parts inside the TV.
Dec 18, 2008 | Toshiba 20HLV16 20 in. LCD Television
Cannot figure out how to remove stand so I can mount TV on wall
did you figure this out? I only ask because I need the stand for my TV. Could you sell me yours?
Thanks
Anthony
amsaxo@yahoo.com
Dec 02, 2008 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Wall mount doesn't fit holes on tv
As your learning a universal wall mount won't work on this set because of the hole configuration, below is a link to one that should work but its not cheap.
AW51 NEW AKAI PDP TELEVISION WALL MOUNT BRACKET PMT4290 NIB AW51 eBay
Feb 23, 2018 | Televison & Video
Attaching to wall mount
The 4 screws that are commnly used are short because they are ususally wide in diameter. Besides if they are too long then they might damage the boards on the TV.
Apr 13, 2007 | Akai LCT2716 27 in. LCD Television
Toshiba 20HLV16 20 in. LCD Television Logo
271 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
