Question about Kenmore Elite 45986 Front Load Washer
He2 washer flashing code f51
During the wash cycle it flashes code f51. If I press cancel and start again it will run for a minute or so. But then start flashing. There is water in the washer with soap. I finally just pressed the rinse spin and drain button which ended that load. Just wish I knew what f51 meant.
  • 4 more comments
  • heatherg24 Feb 09, 2008
    I have the same problem. Code F51, but when you drain and spin the soap does not get rinsed out. Please help this washer is driving me crazy!!
  • debbie 28 Mar 12, 2009
    my machine is a hotpoint ultima, it keeps stopping duringg the cycle and flashing up f5, its driving me mad! i have to keep draining and starting a new wash! some ideas on what it could be please.
  • Anonymous Mar 15, 2014
    ge washer gcrh410, my washer just stoped spining at the end of the cycle and lights started flashing during the cycle. Could it be just a censor?
  • Anonymous Mar 19, 2014
    flashes a code of f51
  • Anonymous Mar 22, 2014
    the washer cuts off in any washing mode
  • Anonymous Mar 29, 2014
    Washer fills only on hand wash cycle, other wise if I use a regular load it fills and then flashes LE code. Other times I have added a cup of Bleach to the wash tray and the run the washer through a wash cycle but this time it just fills and drains the water but will not spin the drum. When it gets to the last 9 to 4 minutes the LE code flashes. What can I do to try and fix it myself?
    New Friend:
    Problem Solver:
  • 5 Answers
I agree with sissssss. For my Maytag's F51 error, there were socks lodged between the inner and outer tubs, causing too much friction on the motor. This led to the computer reading poor performance of the motor. Please consider trying this easy fix before calling out service personnel or replacing circuitry!!! I spent hours under the machine messing with the motor and circuitry until I looked up at the translucent tub and saw stray laundry stuck where it shouldn't be.
* Open the lid. Turn the bottom agitator by hand. Give it a good push. It should continue rolling on for several turns. If not, there is laundry stuck between the tubs causing friction.
1.) Pry open the metal case lid. Take two flat head screwdrivers and wedge them in the crack about 6 inches from the left corner, and use them as levers to pop the metal lid, then the right corner. Lift up the metal case lid and lean it against the wall.
2.) Take off the plastic ring that bridges the gap between the inner and outer tubs. There are many little catches all around the perimeter of the outer tub that hold on this plastic ring. Find those catches and put outward and upward pressure on those to release the catches.
3.) Look down in the gap between the inner and outer tubs for stray laundry. I used a retrieval tool (Lowes 403255) below to grab the socks. There were especially several socks in the back right corner near the pump inlet. Run the drain and spin cycle and look again. There were more strays hiding that I nabbed the second time!
4.) Snap the inner cover on by lining up all those catches and seating them. Snap the big metal lid back on by aligning and giving a good downward thump. Run the machine and be the hero, and don't be too mean to your wife about tossing those socks down in the crevices. Half hour and $3 for the retrieval tool is far better than all that RPS mess.
Posted on May 20, 2013
    New Friend:
  • 3 Answers
Mine gave the F51 code a few min after it started to agitate. Watched a few videos on YouTube and found that the clips that hold wiring harness secure at the RPS had came out. When it started to agitate it must have moved the the wires connected to the RPS to make it think something was wrong. Popped them back in and is working fine. 30 min and no $$$$
Posted on Dec 11, 2012
Check hose inside mine had two baby socks clogging it up
Posted on Feb 14, 2008
SOURCE:
Bocsh 1400 express f21 keeps flashing
This Bosch looks like a Kenmore HE2, and may be made by the same manufacturer.
In the Kenmore HE2 manual it states:
"F" Variables [F4 to F16] (Electrical problem)
Select PAUSE/CANCEL twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call for service.
If it's not working still, try asking advice at RepairClinic.com . They have helped me in the past, and they have parts too.
May 29, 2014 | Kenmore HE2 Plus Front Load Washer
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code F H keeps being displayed about 8 minutes into a cycle. What do I do? Please help laundry is mounding up!!!!
flashes if the washer loses power during a running cycle. The washer does not flash FH" when it is first plugged in.
-OR-
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Keep getting error f20
Press the Pause/Cancel button twice to clear the display and cancel the cycle. Unplug the machine and remove the fill hoses from the water inlet valves. Check the inlet screens for clogging and clean it. Make sure that the water supply valves are open and water is present. Check the drain hose for siphoning.
Press and hold the Start button to start a new wash cycle. If the error code flashes again, verify if there is water present inside the tub. Check the water inlet valve if no water is present. Check the pressure switch if water is present.
Feb 05, 2010 | Kenmore HE2 Plus Front Load Washer
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Won't run
found a pf not an a fp
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
972 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
