Question about Crown CE2000 2-Channel Amplifier
Fan It seen when the amp getts warm It starts to humm a little. I noticed that the fam was not going on. I have been using a standard fan for now and it works fine for keeping it cool. Queestion........ is there a diode or cap or relay switch that might need replacing. Amp works great other then that. Have you ran it this problem yet. I so could use a little insite on the problem.
  • Anonymous Apr 08, 2009
    Thanks guys but it still is causing me headackes. I'd lke to get a troubleshooting chart to trace back through the Amp. Any suggestions?
I had one that was doing that, and it ended up that one of the screws through the main board into the chassis was loose and was not making a good ground connection. Gently loosen and retighten the screws that hold the main board to the chassis.
Posted on Mar 03, 2008
    Genius:
  • 1,175 Answers
The hum is power line hum ( 60 cycle ) . It may be that when the amp gets warm that something in the case wants to vibrate to the 60 cycle hum.
I have amps that hum like that and theyre fine.
Depending on the design of the amp, the cooling fan may not go on till it gets really warm in the amp. Some run all the time like the Ashly I just fixed
Posted on Jan 08, 2008
I have a discontinued modle ceiling fan Hampton Bay Sauterne broke glass globe..is there a replecment for that particule model even if the origional cannot be found..like a standard size of these globes...
There is nothing standard on a fan. If the fan came with the light, then you'll have to contact Hampton Bay(Good luck). That's just a low-end fan made for Home depot.
Mar 16, 2015 | Hampton Bay Dryers
I just bought the 20" floor fan. it has great
The back of the motor is going to get a little more than warm , if you run it wide open for a long period of time. This is normal !!
Jul 18, 2013 | Refrigerators
Hi there, our side by side LG fridge freezer is 3yrs old. We noticed yesterday morning that all the food in the freezer was defrosted and on closer inspection, we see its blowing out warm air instead
There is alot of things to look at first listen for compreser if its running then there is a fan next to it make sure its running if its not you can put a box fan on condenser and compresor and if it starts cooling again u know the fan is the problem this is the most common thing ive seen.
Dec 30, 2012 | Refrigerators
Runs very hot at times cannot leave hand on lay below keyboard area, fan is not on. When it does this I start cooling mamually by pushing fan around with paper clip thru air intake grid until it starts...
Hi rdn52...
Sounds like your cooling fan is faulty...
The computer should not get very hot like you describe...the fan should keep it cool...
Replace your cooling fan...
Please take time to rate me
Sep 24, 2011 | Gateway E-475M Notebook
I have a 2000 sw saturn, thefan dose not run, I jumped the fam and the moter is good. fuse is good fan just womt run
it may be the sensor that activates the fan that is faulty & needs to be replaced......cheers.
Aug 01, 2011 | Saturn S-Series Cars & Trucks
Model #LG LWHD1500ER The fan to cool no longer runs on the low speed. It will just humm. On "energy saving mode" the unit does not always turn on to cool. On the "cool mode" when the fan is on high it...
www.appliancefactoryparts.com/content/.../118816.pdf - United States
Above is your service and repair manual, with this you will be able to troubleshoot and repair your Aircon.
I suspect, your thermostat may have a faulty sensor?
factoidz.com/troubleshooting-your-air-conditioning-thermostat/
http://www.inspectapedia.com/heat/Thermostats.htm
Below is a DIY AC, troubleshooting how to. http://www.repairclinic.com/Air-Conditioner-Troubleshooting
Jun 26, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
DeLonghi ESS601 electric oven
We just moved in to a place that has this oven, if you use the setting with the fan with a circle round it, seems to get hot! Don't know what the other is for though!
Hope it helps!
Pete
Jun 20, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Sony VLP-SC50 lamp shuts down and temp/fan light blinks
that means the fan is broken... say to call sony customer support. Probably gonna charge you an arm and a leg to fix it so im gonna try to nstall a new fam myself
Feb 03, 2008 | Sony VPL SC50 Multimedia Projector
Have had 2 9600xt's that had the fan motor start squealing
Try cleaning the fan with a can of compressed air ,make sure there are no wires close to your cooling fan blades. If this doesnt resolve the problem replace the fan .
Nov 24, 2007 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
Crown CE2000 2-Channel Amplifier Logo
121 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
