Back to:
Tags:
Monitors
Generic problem for all Monitors
PRINTER
posted by threebeemee on Dec 03, 2007
I need to reset my printer from grayscale to color print option
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 03, 2007
Not Rated (0)
ctf1800
Rank:Guru Guru
Rating: 85%, 3432 votes
go to file print, then properties and select color settings or look for a gray check box that is checked for gray scale
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on PRINTER:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Gateway FPD1975W (Black) 19 inch LCD...
My Gateway 19" FPD1975W monitor is not displaying...
Compaq Presario 2700 15 in. Flat Panel LCD...
We turn the computer on, but the screen will just flash...
NEC MultiSync FE2111SB (White) 22 in.CRT...
My power switch has gone bad. I noticed it got stuck in...
HP L1702 (Carbonite, Silver) 17" LCD...
Hello I a a problem with definition. Noise on edge of...
E-Machines eMachines Monitor (E15T4)
I turned off my computer one evening & the next day it...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
