Question about Sony STR-DE525
No Output from any channel
My DE-525 does not give any audio output at all. Turn the volume right up and get a crackling noise and a very faint output. All channels are the same, as well as all inputs. I'm assuming that this issue is related to the input or preamp section. Display is normal and from testing, power seems good too.
Can any one point me in the right direction?
Cheers,
Jeremy.
  • jeremyts Dec 18, 2007
    I'm not sure I understand what you mean. What codes and pin? It's not, and has never, asked me for any.
    Cheers,
    Jeremy.
  • 456 Answers
Ok i got it now may be you are putting the codes in wrong pin thats why happening this problem.
Posted on Dec 18, 2007
I have a 2010 cobalt lt. Today both my feont speakers quit working. And now my turn signals make no noise. Or the door chime or the seatbelt indicator does not work. What causes this and how do I fix it?...
The chimes an turn signal noise come out driver door speaker . Both front speakers not working could be a blown circuit fuse inside the radio or just blown front speaker channel . Your best bet , take it to a GM dealer or someother qualified repair shop . You have no idea of the complexity of this . The radio can set DTC'S - diagnostic trouble codes , believe it or not !
DTC B1025, B1035, B1045, or B1055
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3V AC and slightly higher.
DTC B1287 01: Amplifier Control Signal Circuit Short to Battery
DTC B1287 02: Amplifier Control Signal Circuit Short to Ground
DTC B1287 04: Amplifier Control Signal Circuit Open
The radio provides a remote amplifier mute output circuit to control overall muting of the remote amplifier. The amplifier receives pulse width modulated (PWM) signals on the control circuit at varying duty cycle percentages for controlling muted and unmuted functions of the amplifier. Circuitry internal to the radio monitors the remote amplifier mute circuit for faults and sets the appropriate DTC when faults are detected.
Feb 16, 2018 | 2010 Chevrolet Cobalt
When i turn the volume up from my sony receiver strda3400es de protection comes in. By lower volumes it works ok.
Hello
Measure load resistance. That is the output connected resistance. If it is too low than normal this type of protection will be activated. Measure the impedence [resistance] of speakers connected to the output. It must be more than 4 ohms/channel effectively. OK.
May 17, 2011 | Sony STR-DA3400ES Receiver
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Aug 27, 2009 | Audio Players & Recorders
Speaker Problems
Can you swap speakers and see if the left working speaker works when plugged into the right output?
If it does, then your right speaker is bad or the right speaker cable/plug may be bad.
If the working left speaker doesn't work on the right output, then I would suspect a problem in the right channel audio amplifier.
Please let me know if I can be of further assistance to you.
- Jim
Feb 29, 2008 | Emerson MS3100 3-Disc CD Changer
Sony CMT CP1 Right hand speaker output very noisy, humming, crackling
It sounds to me like you both are having a problem with a capacitor going bad. some capacitors act as a noise filter and it sounds like you both have a bad one. If you are any good with a volt-ohm meter that reads capacitors you should check them to make sure they are at their proper values which will be posted on the capacitor. then replace it. if you dont know how to use a v-o meter then take it to a shop and have them replace it
Jan 21, 2008 | Sony I/M CMT-CP1 98 FRENCH Shelf System
PS3 hdmi Audio problem Crackling Sounds
Go to audio options, and manually DE-select Digital 5.1. That should fix it. It did for me.
Aug 28, 2007 | Sony Playstation 3 (PS3) Console
No output from left channel after crackling sound
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Jul 08, 2007 | Marantz SR-4200 Receiver
Pioneer deh p7500mp
definitely a heat problem. There is a chip (or set of chips, perhaps audio output chips) that work fine when cool, but when they are hot they start to fail. Common problem with IC's. Heat is not a friend of these devices. Time to get it repaired or get a new one, depending on cost of course. Also, do you have an amp attached? Perhaps the amp is the device with the failing IC's.
Aug 09, 2006 | Pioneer DEH-P7500MP CD Player
Sony STR-DE525 Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
