Question about Kitchen Appliances - Others
Russell Hobbs Toaster Model # RH4T9379
The toaster failes to raise the bread after toasted. One side only does not perform.
  • 1 more comment
  • mithund Feb 25, 2008
    Damn! I have the same problem...looks like something messed it up in the recent power surge! And, i can't find another similar one anywhere.
  • dargaud Apr 06, 2008
    Not sure from the description if I have the same problem: toaster raises bred only close to the handle. Either the horizontal bread support is bent (hard to tell) or there's something missing from the other end (it just hangs and doesn't touch anything except the bottom).
    I tried to take it apart but the screws are security-hex garbage and I don't have the appropriate equipment.
  • Blue Topaz Jan 05, 2009
    I am on my second toaster, and it has now developed this fault. To make matters worse, unless you watch very carefully down the toaster slot at the opposite end from the handle when you depress the handle an ensure that the metal bar supporting the bread is locating down the slot, the metal support slips out and bends, resulting in the tabs coming into contact with the toasting element, and then of course it fuses all the electric power sockets in my house. It really is mechanically not up to the job, and its such a shame because the appearance is excellent.
  • 537 Answers
It would be NICE if you didn't abort the chat session when I was tyring to help you. Geez!!
Posted on Dec 03, 2007
Russell hobbs problems
It sounds like the heating coil is not getting power on the side that is not toasting. Return the unit to the retailer that you purchased it from and get a different model or a refund.
May 03, 2014 | Kitchen Appliances - Others
New elements for Russell Hobbs Toaster 9276
go to an appliance repair shop and see it parts are available. go on the web--google-- russel hobbs toaster ---parts department and give your model number.
May 26, 2013 | Russell Hobbs 9276 Toaster
Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
May 17, 2012 | Russell Hobbs 18140 4-Slice Compact...
Russell Hobbs 18140 Toaster The bread carrier will not stay down during toasting. Insert two slices of bread into bread carrier and push down to lock. The right hand side carrier does not stay down. The...
Constant use can lead to crumbs clogging the path of the lever. Try opening up the bottom panel, by pulling on the metal tab to release the plate (and crumbs!) over a trash can. Also try flipping the toaster upside down and, very gently, shaking the crumbs out. if that doesn't work, you can try checking the toaster's browning dial. This might be too low to activate the heating coil. Try dialing it up, and pushing the lever down again. I hope this helps. You can check our post on Best ways to use a Toaster oven. Best ways to use toaster oven 2017 ultimate guide Kitchenutilitypro
Sep 28, 2017 | Kitchen Appliances - Others
Russell hobbs toaster 9379 bread carriage handles won't stay down to toast
bought a new toaster I would like any account you have created for me to be deleted. thank you
Dec 22, 2009 | Russell Hobbs 9379 Classic 4-Slice Toaster
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
Apr 01, 2009 | Russell Hobbs Toaster Ovens
Bread will not stay down
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
Russell Hobbs 9209 Classic toaster
I had the same problem which I managed to solve. The electro magnet that holds the toast lever down takes its power from a poor joint.
Remove the bottom of the toaster. You will see 2 wires encased in a heat proof sleeving going from the small circuit board. One of these wires dissapears up inside the heating element board about mid way along the board. You will now have to remove the metal covering by twisting 6 tabs. This is best done by taking off the black knobs you use to push the toast down - if you can - I couldnt, so I had to use long nosed pliers to bend the tabs and then with difficulty, remove the metal cover. YOu should now see the terminal that the wire is connected to. It is this connection that fails either between the wire and coonnector or connector and heatin element on the reverse side. I put a small bolt through the hole and used a nut to tighten the pressed fitting. I didnt use solder because I thought that it would just melt!
Anyway, my toaster worked after that. Russell Hobbs failed to give me any advice at all.
I hope that has helped.
Neville
Welwyn Herts
Aug 25, 2008 | Russell Hobbs 9209 Classic 4-Slice Toaster
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
559 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
