Hi all, i have a rancilio silvia and a rocky grinder, when i just purchased the silvia i could produce good coffee while grind the coffee on 7level in my rocky, now days its seems that the silvia pressure increased, i have to grind on 2( very near to zero level). i know that the grinder is ok, because i grind for others on 8th level and its good for them, is there a possibility that the pressure went higher? how to check it?
The Silvia comes equipped with a "pressurestat" that may have gone out of adjustment. Do a google search on that and you will find numerous pictoral guides on how to do this. The owner's manual that came with the machine (they have electronic versions at espressotec.com, among other places) will also give you basic instructions. Good luck!
I need to order a part for the silvia rancilio macchine per caffee. I need the filter hoder, two cup...
(More)
I need to order a part for the silvia rancilio macchine per caffee. I need the filter hoder, two cup filer, one cups filer, ground coffee press & coffee measure instructio manual. where can i get these parts?
Rancilio Silvia coffee machine worked once making two coffees.... despite on light being there it is...
(More)
Rancilio Silvia coffee machine worked once making two coffees.... despite on light being there it is now not heating water at all. Tank is full with water.
Last time used was spent trying to perfect steaming milk.
Can you supply a thermostat for a Rancilio Silvia? the one required is T3 in the wiring diagram, and...
(More)
Can you supply a thermostat for a Rancilio Silvia? the one required is T3 in the wiring diagram, and is between the on/off switch and the heating element. In the diagram it is described as "thermostat 165º". The actual stat is marked "Ty 80-R Campini, 16/250~ T210. If available, please quote full price and postage, and terms. Thanks, Colin
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
