Question about Compaq FS7600 17" Flat Glass Monitor
I've bought this particular monitor (along with my "Windows XP" computer) since the Summer of 2005 & it's been used for approximately 3 months. All of a sudden, not only the the screen went bad & went to its "blank" position, but the LED that was under the screen of the monitor stops indicating a flash as well. Finally, everytime I tried applying power to the monitor & turning it on, it constantly makes a clicking sound. These are my symptoms for my "Compaq FS7600 17~Inch Flat~Glass Monitor". Thanks for the help.
  • Anonymous Dec 18, 2007
    Monitor on my Fs7600 has a clicking noise, and the screen is black. However, if tilted gently in opposite directions, the monitor may light up, with no additional problems.
  • 749 Answers
Some electronic components on the circuit was shorted.
clicking indicates this type of problems.
Posted on Dec 05, 2007
Does not boot (hard drive problem?)
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.The hard drive needs replacing and Windows installed on the new hard drive to get your laptop working again.
Feb 23, 2013 | Toshiba Satellite L655-s5075 Laptop Screen...
Click "Start" in the lower-left corner of the Windows home screen, then click "Help and Support." Click "Undo changes to your computer with System Restore" beneath "Pick a task." The "Welcome to System Restore" screen will appear on the screen.
Click "Restore my computer to an earlier time," then click "Next."
Choose a previous time to restore your computer to by clicking one of the bold dates on the calendar that appears on the screen, then click "Next." Click "Next" again when a dialog box appears asking you to verify the restore point. Your computer will be restarted and restored to the previous point you indicated. If restoring that point does not work, repeat the process and restore the computer to a previous point.
CD/DVD Drive Does Not Appear In My Computer
Click "Toshiba Upper/Lower Limit Repair Tool" in the Resources section, then click the name of that same highlighted title in the Resolution section of the document to download the file. Save the file to your Windows desktop. The file name will be "RmvFltrs.exe."
Click "RmvFltrs.exe" on the Windows desktop if you are using Windows XP to run the installer program for the software; if you are using Windows Vista, right-click "RmvFltrs.exe," then click "Run as Administrator." Click "Allow" if User Account Control asks you if you want to allow an unidentified program to access your computer.
Restart your Windows XP or Vista computer to finalize the software installation. Your CD/DVD drive should appear in My Computer.
Display is Blank
Press a key on your Toshiba Satellite laptop. This will wake the laptop up if it is sleeping.
Press "Enter." If you have set up a password protected screensaver on your computer, a dialog box will pop up asking you to enter your password. Enter your password and press "Enter" again to access the laptop. Your screen will be blank prior to press "Enter" because you did not choose a screensaver.
Press the "Fn" and "F5" keys at the same time.You may have hit these buttons previously, causing the built-in laptop screen to go blank because the computer thinks the video is being sent to an external monitor. If you press the "Fn" and "F5" buttons and the display does not appear on the screen, press the buttons again to make sure your laptop screen is set as the default monitor.
Jan 10, 2013 | Toshiba Computers & Internet
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook.
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
Blank screen
Disconnect the monitor , from the computer, switch the monitor on , if you have some kind of Dell self test box running on the screen. The monitor is OK . The problem can be with the video card or resolution settings.
Also, try connectin the old monitor you had hooked up with the system to check ,if you see anything
Mar 14, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Blank screen using Vista x64 with Nvidia Forceware Drivers 8600GT
Most like the sound card you have is not compatible with Windows Vista. You need to check the manufacturers website to see if there is any patch for Windows Vista
Oct 02, 2008 | Computers & Internet
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung CRT Blank Screen
1.Check O/P Voltages that time If U find abnormal voltage of vertical IC supply Pl change supply Diode&IC
2. check 5V supply,change 5v Regulator.
Aug 19, 2008 | Samsung SyncMaster 793DF 17" CRT Monitor
Iiyama Pro 452 clicking sound during start-up
Your CRT Monitor will fail soon. The clicking sound is coming from your CRT's power circuit.
Make plans now to replace it. This problem is known to be a fire hazard in some cases. So, better safe than sorry.
Sorry for the bad news.
Hope this was helpful.
May 21, 2008 | iiyama Vision Master Pro 454 19" CRT...
Blank Monitor Screen
Jan 03, 2008 | Gateway FPD2275W LCD Monitor
Problem in monitor the screen doesnot get full wide of it by control panel
Assuming your running Windows as the operating system on your computer, go into Display Properties and set the refresh rate to something other than 60 hz or default. On my XP computer this can be done by right clicking on the desktop, clicking Properties -> Settings -> Advanced -> Monitor. Anything in the 70, 72, or 75 hz range should work fine. If this does not fix the problem and the monitor is out of warranty trash it and get another one.
Nov 10, 2007 | Hansol 730E 17" CRT Monitor
Compaq FS7600 17" Flat Glass Monitor Logo
150 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
