Question about Sanyo DWM400 DVD Player
DVD not reading disk
I'm having a problem with the DVD. When I put a DVD in there it is telling me no disk but it plays music CD's. I tried calling the 1-800 number but it is busy. Can anyone help me.
  • 77577 Dec 03, 2007
    Yes I have tried other DVDs and it is reading the same thing but like I said it plays CD.
    Okay what does that mean the lazer is weak. What do I have to do to fix it.
    President:
  • 4,402 Answers
Have you tried other DVD's disks im thinkg your laser is getting weak.
Posted on Dec 03, 2007
  • Cary Farah
    Cary Farah Dec 03, 2007
    I think the laser is week, dvd's require more power from the laser
  • Cary Farah
    your would have to have it replaced and it would have to be done at a service center since it would have to be aligned, usually cost more to have it done than it is to buy a new one.
SOURCE:
How do I get the movie to play ,because the music CD plays
Make sure you have the correct adapter for your CD player to plug in.
Dec 27, 2014 | Durabrand PDV-709
My hp 4520 probook is not picking up the cd/dvd drive, no type of cd is visible in "Computer" folder or accessible. It does not automatically pick up the cd/dvd and ask usual functions like "open with"...
no OS stated, no CD stated, but asks...
there are vast types of CD disks, not one stated by you
what is ? whats on it , what does the label say is it home made CD
non of that can we know, and is KEY to the best answer.
for autorun to work 4 things must be good.
1: the CD drive shows up in device manager, and be OK.
2: the CD must be good. what is it, not stated by you. yet.
3: the autorun feature turn on via the My computer explorer.
4: the CD must have an autorun file, many dont.
so lets forget AUTORUN, (must walk first then run, LOL)
first as always it the DRIVE must be pulled in and not bad.
2nd the Device manager must show it as must next it shows, up
in Diskmanagment and last must show up in My Computer.
or in W10 that is now called. THIS PC.
Microshaft changed this name for local explorer 4 times. for kinks.
and sux that, having to tell that.
sure seen this 1000s of times.
and all ways from sunday , you name it ive fix it,
even bad media or media from China it this pure trash.
lets say the Device manager, shows the drive.
what to do next? well that is easy
go to walfart and buy a music disk
this is called a CD-DA disk.
this disk works on all optical drives made.
if you see it in MY computer and click it , it will play.
music. as designed to do .
one other thing to do us load the Probook drivers from HP
on the PC, matching what drive you have,
mine is a DVD drive, upgraded. and can burn DVD-R.
if you have windows install disk put that in,
now.
you can see files now for the first time if the CD is a DVD
and the drive is a DVD drive, you see fails.
if the MS orHP disk is DVD and the LT only has CD drive
its hopeless.
if you have modern drive you can read most files.
even MP3., WAV music
and watch movies on DVD.
if you upgrade to BRD, blue ray drive you can run BR movies.
Older cd/dvd drives many not be able to see or run
any burned drives, the first ones could not do that.
like DVD-r or DVD+r home burned disks.
again see if a real store bought music disk works (CD-DA)
if that works good move up to more complex disks and test.
if not the DVD drive is dead, or the drivers do not match your drive.
to match any drive.
remove it and read the number on it.
it has a tag.
so you said all type but do tell if it is a store bought CD first.
for music, not a burned disk by you or others.
a disc from a store, real, music and not scratched up.
got this one? there are many types offered and used,
AD-7586H?
Jun 23, 2017 | HEWLETT-PACKARD HP ProBook 4520s Notebook
IBM GCC-4242 N CD-RW/DVD DRIVER WILL NOT READ OR PLAY CD, BUT WILL READ AND PLAY DVD
try a blank CD disk or a CD format with data (like software o VCD)
some old driver may not real music CD disk.
Dec 29, 2009 | IBM ThinkPad T40 2373 Notebook
I had to download all kinds of drivers to get my computer to do basics like viewing movies hearing music and finally burn music now i learned i can only save data(lots of songs at one time) or make a cd on...
cd-r80 are for music. Your best option is to buy a program like nero. I assume you are just dragging and dropping files to burn them right now. dvd's are more meant for backing up data or making movies because they hold a lot more data then a cd. Are you able to burn disc's at all? Just like all things involved with computers it can get complicated real quick.I hope this helps a little and if you have more questions let me know
Thanks,
Lee
Nov 05, 2009 | Dell Inspiron E1505 Notebook
Readable DVD's but not CD's
That is a faulty lens. The lens reads DVD and CD on different laser beam frequencies. To read the TOC initial track the lens must focus on the laser beam reflected by the disk. If the lens is opaque, scratched or dirty, sometimes it can focus on DVD but not on CDs or the opposite.
Try using a cleaner disk, if that does not work buy a replacement drive. Today you can get a dual layer DVD RW for less than $30.
Sep 25, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
When Palying a CD Music skips (Media Player)
Greetings my friend, regarding on your problem try to check or clean your CD/DVD ROM. Try to clean it with disk cleaner cause sometimes we forgot to cleam the important part of CD/DVD ROM its eye the one that reads all the dat in the disk. So try to clean it and play the disk again after you clean. Also try to clean also the disk you want to insert in your CD/DVD ROM in order to prevent this problem again.
Jun 16, 2009 | Computers & Internet
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
I have an HP Touchsmart computer. When I put a data or audio CD in my DVD/CD drive, it sounds like it is going to start up, the light comes on like it is going to run, but nothing happens. Sometimes, it...
CDs means totally nothing. sorry....
what CD? , a CD-R? CD-RW, or a store bought CDDA disk
all 3 are different. (or DVD? of vast types too...)
my guess you meant CD-R. (CD record-able)
TouchSmart IQ770 PC Desktop? 2007 carbon date?
what OS, XP, VISTA or W7?
My guess its bad media or bad CD drive.
only way to prove that is use new CD-R burned on good system slow.
say using the great free utility called, imgburn.
first try a real disk, from a store, from the Music section
called CD-DA disk, play it , if it plays the CD drive might be ok.
then try what I call rubber disks, recordable. CD-R
using pro grade disk burned correctly.
buying the cheapest media can be a nightmare. here.
tell HP your OS
the as an example (i guessed OS, means operating system)
install this up date, called HP HP Personal and Pocket Media Drive Driver Update
here.
https://support.hp.com/us-en/drivers/selfservice/hp-touchsmart-iq700-desktop-pc-series/3351217/model/3351218
Apr 11, 2017 | HP TouchSmart IQ770 PC Desktop
Sanyo DWM400 DVD Player Logo
75 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
