Question about Creative Labs MuVo V200 MP3 Player
Fill system error in muvo v 200 usb
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
It says File system error when I turn it on and then it turns itself
I have an problem as i/o errror be connecting with usb port
Posted on Jan 21, 2008
    President:
  • 4,402 Answers
It can also be caused by transferring DRM (Digital Rights Management) encoded media files via the drag and drop method. It is recommended that you use the drag and drop method to transfer audio files that are not encoded with DRM. If in doubt, use either Creative MediaSource Organizer or Windows Media Player to transfer your files.
To resolve this difficulty, we recommend that you format the player and transfer the content again. You can also download and install the latest firmware, and select the Format Data Area option during firmware update.
To format a MuVo player, connect it to a USB port on your PC. Open the Windows Explorer, and locate the Removable Drive listing and right click on it. Select Format, and choose FAT instead of FAT32 or NTFS. After the formatting is complete, make sure that you stop your player before disconnecting it from your PC (see above)
To update or reload the firmware for a MuVo player, select the model of your player from below.
http://193.95.171.84/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=702,E=0000000000295070241,K=561,Sxi=1,Kb=ww_english_add,VARSET=ws:http://us.creative.com/,Case=obj(4656),Kb=ww_english_add
Posted on Dec 06, 2007
  • Cary Farah
    Cary Farah Dec 07, 2007
    http://us.creative.com/support/downloads...
  • Cary Farah
    Cary Farah Dec 18, 2007
    • "FixYa!" -
      The solution provides great advice on how to solve the problem.
    • "Helpful" -
      The solution provides helpful information that helps solve the problem.
    • "Thanks for Trying" -
      The solution provides some help but does not solve the problem.
    • "Inappropriate" -
      The solution has nothing to do with the problem.
SOURCE:
My mp3 creative muvo v 200 can not formated, but icant use to hear a radio but i canot save my mp3 song when i backup file is still can see my mp3 file please help me what can ido..????
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Mar 05, 2009 | Creative Labs MuVo V200 MP3 Player
File System Error
I am getting the File System Error in my MuVo v200. What can I do to fix the problem?
Thanks for your help....
May 28, 2008 | Creative Labs MuVo V200 MP3 Player
File system error
you may need to format the device > insert device to your PC > go to my computer and format to FAT instead of FAT 32.
Mar 26, 2008 | Creative Labs MuVo Slim MP3 Player
MuVo s200 Bad upgread
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Creative Labs MuVo S200 MP3 Player
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
Nov 26, 2007 | Creative Labs MuVo V200 MP3 Player
I/O device error
My MuVO TX was having problems until I installed the latest firmware. The last firmware release was in March 2007. If you haven't updated the player's firmware since then, try downloading it and installing Creative MuVo TX FM Firmware 1.24.02.
If you can't get your computer to even recognize the player anymore, you could try reinstalling the Creative Mass Storage Driver 1.07.00.250.
Oct 10, 2007 | Creative Labs Nomad MuVo TX MP3 Player
Error
Did you format it properly?
Usually MP3 Players are to be formatted with the FAT32 File System. This can be easily done on Windows.
Simply connect the Mp3 Player to your computer via the USB. Then Windows should be able to detect it just fine. Go to My Computer and right clock on the new device (that is the MP3 Player) and select "Format".
Format as FAT32 and try again.
PS: You may want to backup all data (if that is possible) before you attempt this Format thing.
Oct 03, 2007 | Creative Labs MuVo Micro N200 MP3 Player
System error
This firmware upgrade only works with Creative MuVo Micro N200 players. Do not install this upgrade to other players.
You will lose all content in your player when you install the firmware. Back up any audio or data files in your player to your computer before upgrading the firmware.
Before installing the firmware, please complete the following procedures:
  1. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe.
  2. Connect your player to your PC.
  3. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications.
  4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen.
To install the firmware for your player, follow the procedures below:
  1. Download the firmware update, MuVoN200_PCFW_LF_1_20_04.exe to your hard drive.
  2. Connect your player to your PC if it is not already connected.
  3. Double click the firmware upgrade file.
  4. When prompted to set your player in Recovery mode, disconnect your player from your PC.
  5. Remove the battery from the player, press and hold the Play button while connecting the player to the USB port.
  6. Continue to hold the Play button for about 10 seconds after your player is connected to the USB port.
  7. When the Find New Hardware dialog box appears on your PC screen, release the Play button.
  8. If this is the first time a player is installed as Player Recovery Device, Windows will find a Player Recovery Device (or USB Device), and prompt you for drivers. Click on No , and select Do not search. I will choose the driver to install. Windows will install the necessary drivers automatically.
  9. Double click on the downloaded firmware again (MuVoN200_PCFW_LF_1_20_04.exe) to update the player's firmware.
  10. During the firmware update process, make sure to check the box next to Format Data Area under Download options.
Feb 02, 2007 | Creative Labs MuVo Micro N200 MP3 Player
Problem with my Muvo S200
man i think i have the same problem with my device also you better go to nearby vendor or register online and ask for the warranty support from the manufacturer the i\o error signifies the device has become corrupt
Oct 11, 2006 | Creative Labs MuVo S200 MP3 Player
Muvo v200 issue
Hey guys, is this problems only happens on MuVo V200 models only?? or there?s only such errors that they might encounter often??
Aug 09, 2006 | Creative Labs MuVo V200 MP3 Player
Creative Labs MuVo V200 MP3 Player Logo
382 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
