Question about JVC AV-27S33 27" TV
Greeish Tint Color
My JVC AV-27S33 has a greenish color on every channel. I tried to change the color setting with the remote and the tint but it didn't seem to improve. This TV is going on 5 years now and hasn't given me any problems til now. Any suggestions on how to fix this is appreciated. Thanks in advance.
  • 2 more comments
  • esc0
    esc0 Dec 05, 2007
    TV been in place for about 4 years now. There is no speaker close to it. On top of the tv I have my dishnetwork receiver and a dvd player. That's it.
  • esc0
    esc0 Dec 06, 2007
    ctf1800,
    Are you referring to the tv model as well? Or just the color? Because I am having issues with my JVC AV-27S33.
    And if your referring to the color on that Philips in the pic then the answer is no. It has a greenish color to it on all channels. I will see if I can get my hands on a camera to take pics of it. Thanks.
  • esc0
    esc0 Dec 10, 2007
    Here is the pic. I think I uploaded it on the wrong place. Here is the link to where I initially uploaded it the first time.
    http://www.fixya.com/support/t292971-jvc...
  • membur Jun 07, 2008
    I have the same problem, but my TV has a red tint to everything. Black & white pictures appear as sepia color.
    Any suggestions how to adjust color other than the standard menu corrections, which I've tried to no avail?
    I also have the dark picture as described on another entry. Pictures depicted as night time or in dark locations appear as a virtually black screen. Using the onscreen menu, I've set the picture at the brightest setting. Still can't see night scenes.
    President:
  • 4,402 Answers
Have you move the tv or is there a speaker that you might have move close by the tv?
turn the tv off for an hour and turn it back on see if the degaussing can correct ir other wise it may have a bad connect on the degaussing or you have some kind of magnetic device close by.,
Posted on Dec 03, 2007
  • 1 more comment
  • Cary Farah
    Cary Farah Dec 06, 2007
    does it look like this:
    http://www.hdtvoice.com/voice/showpost.p...
  • Cary Farah
    just the color? Because lots of tv's are have the convergance problem a picture would be helpful.
  • Cary Farah
    Cary Farah Dec 11, 2007
    Looks like the red gun is missing, you can look or tap on the circuit board that attaches to the picture tube (don't tap to hard you may break the tube) to see if it has a loose connection, otherwise i would look for the red output transistor bad.
SOURCE:
Color shows greenish tint
Try a different video cable or make a careful inspection of the pins in the video connectors. Look for bent or missing pins. Your missing a color channel.
Jun 30, 2014 | Dell IN1910N 19" Monitor
JVC AV-27S33 only displays black and white (Color gone) Menus are still in color!
Check its color system adjustments. It will be best to make a factory reset to this set. Just unplug the TV from AC mains wall socket, and re-plug it after 10 minutes of so. This must make your TV a hard reset. If this do not help you, the chroma section circuits of your TV need to be checked for fault/s. This is a skilled work, and it will be best to contact any experienced service technician.
Jul 04, 2012 | JVC AV-27S33 27" TV
Jvc hd 52g787 my position adjustment in my menu will not highlight so i can adjust picture over to the left. help please
Hello
Just make the picture status button on the remote control and get the display setting to its factory mode.
The VIDEO STATUS button gives you a choice of three TV picture display settings, including a
display of your own preferences.
Standard - Resets the picture display to the factory settings.
Dynamic - Heightens contrast.
Theater - Gives a rich, film-like look to video. (AV-27D303, AV-27D203 and AV-20D303 only)
Sports - When you watch a sports program. (AV-27330, AV-27320 and AV-27S33 only)
Press the VIDEO STATUS button repetedly to get these choices.
Aug 13, 2011 | JVC AV-27750 27" TV
My TV will not change channels it seems stuck on channel 2 This is true with the remote and with the buttons on the set.
Try to change the channel by manually putting the numbers in with your remote. If this works then you probably need to program your channels.
Aug 21, 2010 | JVC AV-27220 TV
JVC AV-27S33 27" Picture
I've found several bad solder joints on the neck board of my JVC 32' leading to the exact same issues as yours. Inspect the Driver resistor solder on the neck board.
Dec 10, 2007 | JVC AV-27S33 27" TV
Tv has a brownish green tint to it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Dec 03, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC AV-27S33 27" TV Logo
189 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
