Question about Universal Remote Control Remote Control
Won't turn tv on & off and won't change the volume
If I manually turn on both the vcr and the tv, I can turn channels with the remote. Our universal remote stopped allowing me to turn the TV on and off, and the volume buttons won't work. I can turn the vcr on and off with the remote.
  • Anonymous Mar 23, 2014
    Volume works with tv code but channel keys don't. Channel keys work with cable but not volume
  • 113 Answers
Reset the codes using the manual
http://www.sentryindustries.com/category/remotes/remotes_rmc10.asp
If not get a new one.
Posted on Mar 05, 2008
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
Remote CTL model RM-V210 doesn't allow programming of the VCR.
Dear sir/madam,
http://www.thompsontv.com/rcarc.html
click the above link and programmed your remote control..
thanks
good luck
Oct 01, 2008 | Sony SLV-679HF VHS VCR
None of the codes listed works for my panasonic television. None of them will allow me to use the channel or volume buttons and only one of them allowed me to turn the tv off. Now that one doesn't even...
Hello
I'll give you some universal remote control codes for Panasonic to check it with your remote control They are used as general universal codes for panasonic.
Three digit universal remote codes to check with are:
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit unvicersl remote codes to check with are:
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 21, 2011 | GE JASRM24912 Remote Control
Magnavox 20MC4304 20" TV/DVD/VCR Combo Remote:
A universal remote should solve your problem. You should be able to find one on ebay. You may even be able to find one for your particular TV on ebay as well.
Dec 03, 2017 | Magnavox NE206UD TV/VCR/DVD Combo Remote...
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
Hello I have a philips universal remote, don't know what model it is I thought all Universal remotes was one Model. Last night I tried using it for my TV to swich from TV to DVD and it just stopped...
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Dec 01, 2008 | Philips Magnavox Learning Universal Remote
I have a philips universal remote and an Rca Tv how can I program
code list is also listed
Nov 28, 2008 | Philips Magnavox Learning Universal Remote
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Quasar VV-2009
Here is the link to the manual if you need it; http://service.us.panasonic.com/OPERMANPDF/VV1309.PDF check page 26 item 4 - vcr lock - just a possibility this may solve the problem, long shot. Let us know which remote you have and we may be able to find out how to program it for your tv. page 37 gives you contact details if you want to buy the correct remote. I suspect that with the correct programming, your universal should work fine though. Hope this helps :)
Mar 16, 2007 | Quasar TP-2009D 20" TV
Universal Remote Control Remote Control Logo
164 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
