Question about Sony CDX-GT200 CD Player
Buttons are jammed or frozen
All the buttons are frozen or jammed the only thing that works is the cd release and the power button on both the reciever and remote what should i do
    Genius:
  • 1,153 Answers
See if you can do a hard reset, look for reset button in corner or kill power for more than 15min.
Posted on Dec 03, 2007
SOURCE:
Canon Pixma MP160 stopped working, showing E 2 - paper is not jammed - Printer is NOT hooked up to a computer - only used for scan and print in farm shop (heated) - suggestions? It is an oldie but a...
First thing to try is pressing the "Stop/Reset" button. If that doesn't work, hold it down for more than 10 seconds and release. If that doesn't work try turning off the printer, unplug the power cord for more than 10 seconds then reconnect and turn the printer on again.
If the printer was connected to a computer, there might be more information provided about the source of the problem. Otherwise, a last resort would be to reset the printer. Follow this exactly:
  1. Turn off the printer (using "Power" button) but leave it plugged into the wall socket.
  2. Press and hold the "Stop/Reset" button (red circle in the triangle), and without releasing the "Stop/Reset" button, press and hold the "Power" button (indicator light shows green).
  3. While holding down the "Power" button, release the "Stop/Reset" button.
  4. Continue holding down the "Power" button, double click the "Reset" button and release the "Power" button.
  5. Click the "Stop/Reset" button four times
  6. Press the "Power" button to confirm and turn the printer off. Turn printer on again.
Feb 18, 2015 | Canon PIXMA MP160 All-In-One InkJet...
How do I fix my frozen e reader
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 19, 2013 | Apple iPod touch 1st Generation (8 GB) MP3...
My htc hd2 it get frozen at the TMOBILE logo "STICK TOGETHER" i profomed a soft reset by pressing the little small button pn the back of my phone and it still does the same thing
you will have to perform a hard reset and here is how you do it
Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons. While holding the volume buttons, press the END/POWER button briefly and then release it. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Thumps up if this works :-)
Sep 01, 2011 | HTC HD2 Smartphone
I have a CD jammed in my VW Beetle 2005 player. I
Most CD players have a reset button.looks like a very tiny depressed button...push it while you press on the eject button.
Jan 02, 2018 | Volkswagen New Beetle Cars & Trucks
I unplugged my itouch from PC while connected now it's FROZEN!!!
Press and Hold the Home button and the Power Button until it reboots.
If it doesn't help try putting it in recovery mode and hook it to itunes.
here is the procedure.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
let me know if i can help further
Jun 02, 2009 | Apple iPod touch
Digital tuner frozen will not scan
While the TV is turned on, perform the following steps to hard reset the TV:
  1. Press and hold the Input Source button.
  2. Press and release the Power button.
    The TV turns off.
  3. Press and release the Power button.
    The TV turns on.
  4. Wait 10 seconds.
    A message appears saying the TV has been reset.
  5. Release the Input Source button.
Jan 04, 2009 | Dell W3706MC 37 in. LCD HDTV
Paper jam
try this
Open up the printer as much as possible and turn it upside down and shake it (be careful with the scanner lid though). See if anything falls out
or this service mode
  • Turn off the printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for three times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • May 26, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    GPS 910 HAS FROZEN SCREEN
    First, do a reset:
    http://www.tomtom.com/support/index.php?Language=4&query=reset&FID=7134
    If no result, do a hard reset:
    1. Hold reset button pressed for approx 15 sec
    2. Press power button while pressing reset button
    3. Release reset button while still pressing power button
    4. Device should start, hold power button pressed until you see white text on screen, last line should read "RTC..."
    5. Release power button
    Apr 29, 2008 | GPS
    My sansa e200 is frozen and none of the buttons work
    Try resetting your unit. Hold down the power button for 20 or more seconds; when you release the power button, the Sansa Connect will restart on its own. If it doesn't restart, you did not hold down the power button long enough -- try again. Hope this helps:) Jason
    Sep 04, 2007 | SanDisk Sansa m240 MP3 Player
    Sony CDX-GT200 CD Player Logo
    494 people viewed this question
    Top Sony Car Audio & Video Experts
    xxxxxx xxx
    Mike Duncan
    Mike Duncan
    Dalynn Turner
    Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
