Question about Kenwood KAC-728S Car Audio Amplifier
No power turn on??
The positive from the battery is 12v the remote wire form my deck is reading 12v. now when i connect the pos and grd, it still reads 12v, as soon as i connect the remote it reads 8.5v from the pos and the remote to grd. and no power on to the amp. I just dont understand. Please help!
  • twfjohan Dec 04, 2007
    yeah it happens only when i connect the 12v remote otherwise all voltages read correctly. I am starting to think its a blown cap.
  • 631 Answers
Does the voltage at the battery drop when you connect 12v to the remote terminal?
If not, there is too much resistance in the power/ground wiring.
If the voltage drops at the battery, either the battery is weak or the amp is drawing excessive current.
Posted on Dec 03, 2007
  • Perry Babin Dec 04, 2007
    Although it's possible for a capacitor to short, it's not nearly as common as shorted output tranistors. If the amp is drawing excessive current, I'd suspect shorted output transistors.
    Did you check to see if the voltage was dropping on the battery terminals?
I have a rockford fosgate punch 800 car amp and the problem i seem to be having is everytime i connect my remote wire to my stereo deck and i turn my stereo on it burns the fuse its only when i connect my...
Check the wires at the amp. Make sure that the wires are neatly bundled and clean cut when connecting them, a stray wire may be going under one of the connections from the battery input to the ground input of the amp, there for causing a direct short and blowing the fuse. I am assuming you mean that the amp's fuse is blowing. Get yourself a test light and test the wires for power. battery power?(12V) is always on and remote power(12V) comes on only when the radio is on(it should be the blue wire in color). Then make sure you have a very good ground, I always use the seat belt bolt or car seat bolt(direct to chassis). If you checked all these steps with no luck then the culprit may be your amp.
Jul 22, 2011 | Car Audio & Video
Do i havde to have thed module hookec up in order for the amp to turn on?
u have to have the positive wire running from battery to amp and the neg off the amp grounded to metal in the trunk then u most have the remote wire running from the back off the deck to the amp if it does not power the amp and u ran the (+) (-) the right way then that means u did not connect the remote wire which is blue to the right wire in the back of the deck when u do that the amp will turn on. the remote wire is for when u turn ur car off the radio shuts off with it but it has to be connected to the right wire on the back of the deck in order for the AMP to power up.
May 18, 2011 | Kicker ZR600 Car Audio Amplifier
I just bought a Panasonic CQ-C1301U deck, and want to install it into my car. The wiring schematic is not the same as my wiring harness. Which wires are which? (Grey, Grey with black stripe,Yellow, Blue,...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
Nov 11, 2010 | Panasonic CQ-C1301U CD Player
Amp wont turn on and theres power to the amp and the fuses are good
check the ground to the amp. then check the remote wire. make sure u have the sub option on ur stereo turned on. if all is wired up correct an u do not have the subs turned on in ur stereo settings then the stereo will not send power through the remote wire an therfore your amp will not power on.
Apr 04, 2010 | Rockford Fosgate Power T3002 Car Audio...
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
Hi i have fusion sub woofer can u help me to install just let me know how to install many wires so dotn know who to install in my car
  1. Batt + or B+ or Positive.
    This is the connection directly to your automobiles battery. It should be a fused connection rated to about 15% higher than the fuse installed in your amplifier.
  2. Negative or '-' or Ground.
    This wire should be just as thick as the 'Batt + or B+ or Positive' wire. This wire can attach to any solid clean metal connation in the vehicle. Usually a trunk latch.
  3. Remote or amp startup wire.
    This wire is a thin 12V wire that will come from the deck. It's a signal wire that tells the amplifier to turn on.
  4. Inputs
    Low level inputs are in the form of RCA connectors and will require that your deck or head unit has low level or RCA outputs. High-level inputs are used for stereos that don't have low level or RCA outputs. They work by taking an audio signal directly from the vehicles speakers and then amplifying it as necessary.
  5. Speaker connection.
    Match the + and - these with the appropriate connectors on the speaker box. Red means + and Black means -.
    I hope this helps.
Jul 06, 2009 | Fusion FEW12PK Car Subwoofer
I got a stock ford JBL amp with no wiring diagram i need to know what wires are what i have tryed to test for the power wirer but no luck.
ok on most amps there are two sets of wire ports one for speakers & one for +12v,grd & 12v remote start if you look over each port it will say what port is for what wire if it is in a connector it gets slightly more complecated what you do is with a vm check from wire to chassis ground [like seat bolts] 12v with key off when you cet power isolate wire then turn key on till radio comes on then do the same test for 12v isolate that will be remote start then turn key off &check from the first wire to other wire for ground to find speaker wires connect a regular peace of wire to chassis grd & touch the wires you will here the speaker pop be sure not to hold the wire on long cause it will blow the speaker
Jun 04, 2009 | JBL BP1200.1 Car Audio Amplifier
Green light, No Power
Disconnect the remote wire and make a jumper at the amp from the 12v + to the remote input and see if you get the same results. If yes, then you probably have a bad ground point. It might not be able to handle the transfer load it's receiveing. If no, then you have an issue with your remote wire or power wire. Check for any kinks or pinches in the wire.
Jan 25, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Quick question about the power
The remote turn on terminal on the amp needs to be connected to a switched power source. Typically, it's the remote turn-on/power antenna wire on the head unit. If your head unit doesn't have such a control wire, connect the remote turn-on terminal to a wire that's controlled by the ignition switch.
It's VERY important to fuse all of the wires properly. If you're unsure of the proper fuse for a given wire size, read pages 14 and 16 of the Basic Car Audio Electronics site.
Let me know if you have any other questions.
Oct 21, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Remote wire
You have the REMOTE wire hooked to a constant +12V source. The remote wire is supposed to correspond to the ACCY wire to the vehicle, usually through an aftermarket Audio DECK. If it is reaming on when turning the key OFF the wire you currently have it spliced to is a CONSTANT +12V , which is connected directly to the battery. If you do not have a aftermarket Deck, hook the remote wire to the ACCY wire conecting to the factory radio.
Jun 19, 2008 | Car Audio & Video
Kenwood KAC-728S Car Audio Amplifier Logo
144 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
