Question about Bissell CleanView 3596 Bagless Upright Vacuum
My vacuum get cloged
My bisslle 3596 clean view deluxe alway gets a clog of fur and dirt in the hose. my filters are clean and i on clog the problem shoud i take the vaccum apart? i haved to unclog at least once a week. its was a great vacum its been doing this for 4 months. i ready to just buy another vacuum for animals
  • Lucn Dec 11, 2007
    I also have the same problem with my bissell cleanview. Its getting clogged with peices of carpet though, not hair. If I clean out the hose it works good for about 2 minutes, Any info would be great
  • Nicaland Feb 24, 2008
    I'm having the same problem with items getting clogged in the hose. When I clean it out, the vacuum makes sounds and operates like it is sucking items up, but it's just an illusion. I checked underneath the roller already, too. When I try to use the attachments, I still have a problem, which to me, indicates the problem is somewhere inside the vacuum. Of course, I'd prefer to not have to open up the whole unit, but I really don't want to buy a new vacuum yet. I've only had this one about a year or so.
I can only comment on what I did: Ran very hot water down the hose and used a 4 foot 3/4 inch dowel rod to push the clog down to the end where it hooks onto the vacuum. It clogs frequently with pets, you just have to keep cleaning it out.
Posted on Dec 21, 2009
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Check the bottom under roller look in hole run hanger in it a little ways if u pull n e thing out it might be clogged there
Posted on Jan 06, 2008
Why does the thermal protection keep shutting the vacuum off?
Hi! It appears your thermal protector sensor has kicked in and caused your cleaner to power off. This is usually due to a clog or a filter that needs to be cleaned or replaced. Try these steps to get your vacuum back up & running!
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Clean the filter as suggested by the owner's manual.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Your vacuum should turn back on after it cools off, this can take up to an hour. Hope this helps!
Jun 28, 2014 | Hoover Vacuums
Dirt Devil Ultra Vision vacuum- no suction?
Check for a clog at the neck of the "bag".
Sep 11, 2017 | Dirt Devil Vacuums
The dirt is staying in the hose when I vacuum, not
that means there is no air flow thru your machine .. thats often caused by clogged (other) filters ..or sometimes a clogged hose .. you can check to make sure you can poke something thru the hose .. a stick or handle, hose or wire (making sure you dont poke thru the side of the hose) .. there are other filters and passageways in the unit that require cleaning or replacement .. if they get clogged then you will have your simptoms .. since there is lilttle air flow then the motor may overheat .. so dont run it long in that condition .. take all the "dirt cup" parts out and wash them all ...
Dec 22, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
This vacuum keeps getting clogged in the hose and has terrible suction. The women who helps clean my house won't even use it as it performs terribly. Any suggestions
check vac air filter(not the dirt collection bag) also something could be lodged in hose mechanism so there is always a partial restriction. make sure the beater bar is not set too low. check the dirt that accumulates in bag to see that there is not an excess number of carpet fibers in there. beater bar should be clean and spin freely.
Oct 10, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Dirt gets caught up in filter instead of in removable container
That is the problem with the bagless cleaners. The dirt goes through the cup, directly to the filter. There is nothing to keep them seperate. You can try putting a single layer of paper towel against the filter. It will provide a breathable barrier for the dirt but, it will clog too.
Aug 24, 2009 | Bissell 3576 CleanView II Bagless Upright...
Hoover Deluxe Elite Rewind does not pick up
Check the hose and take the bottom plate of the vacuum off to check for obstructions that you can't see right away. Use a wire coathanger (unwound) to push any clog through. I also have dogs and this vacuum. It does get clogged with fur occaisionally.
Apr 08, 2009 | Vacuums
Suction always seems very poor
you have to have something clog somewhere
Feb 09, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
My eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Jun 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Bissell CleanView 3596 Bagless Upright Vacuum Logo
159 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
