Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dvd recorder dmr ez47veb
I am on NTL cable and having problems tuning on auto tune it comes up no channels found it tunes okay on a freeview arial is this recorder compatible with cable any ideas thanks
  • 70 Answers
If your cable is connected with just a scart lead (in AV2) you just put the recorder onto the AV2 channel. You need to connect the cable decoder to the recorder via an arial lead to be able to tune it in but there is no need just use the AV channel.
Posted on Jan 03, 2008
  • Tony Burn Sep 20, 2012
    That is the problem as I cant tune into AV channel or Freeview reception.I may have to try getting a Freeview box with RF modulater.
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Pixelated picture on all channels when viewing tv through xw380 recorder
If you are in a good reception area and your tv channels are coming fine it does look like a recorder issue, try another HDMI cord just to be safe, now when you tried in the shop was that through a different tv? if that is the case the input signal needs to be checked with another device.
Apr 14, 2012 | Panasonic Dmr-XW380 Dvd Recorder
My mother has a Panasonic DMR-ES20D DVD recorder it plays back DVD's ok but has lost all tuned channels. When performing a auto tune it gets to ch 53 and appears to hang with error code U80 in the dis
could be its not digital, so it will not pick up any channels as they are now all digital not terestrial through the aerial like the y used to be. you need a digi box now to plug the recorder into
Dec 11, 2011 | Panasonic DMRES20D DVD Recorder
Om my Panasonic DVD Recorder Model No DMR-EX85EB I have lost tuning to the Digital Decoder for freeview channels. Annalog tuning is working ok. At a gues do you think this would this be a simple repair?...
Open the device and remove the hard drive.
Look at its assembly's legs. If they are bent they have probably cracked the board.
Looking at the device having the front side towards you, look at where the upper right screw from the hard drive's assemblly was. You'll notice the board is broken just there.
If it is, you'll have to remove the whole board and rebuild the broken tracks underneath, usually a pair of them.
Hope you can solve the issue. Good kuck!
Apr 11, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Tuning tv stations for panasonic dvd recorder DMR ES15
Set your TV to channel 3 or 4. Then press TV/VCR which is above the button on the bottom right of the remote. Then you can tune in TV stations from the unit.
Aug 20, 2008 | Panasonic DMR-ES10 DVD Recorder
Manual
If you are looking for a replacement manual, please see below.
Panasonic DMR-EZ47V Replacement Instruction Manual
Apr 02, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
DMR-E85h
That's frustrating huh! I finally found someone at the cable company that knew somthing.. I think it's channel 95 (might be 94), if you tune to that channel, sometimes it get's it immediately, other times it needs some time to download it. But make sure you're tuning to that channel in your line up. In the setup mode you can specify it if it doesn't do it automatically. (just spend some time in setup and you'll see what I mean)
Nov 14, 2007 | Panasonic DMR-E85H DVD Recorder
Can't tune cable box to channel 2 to set up TVGOS
then you can try channel 3 or 4 if that does not work then you have to replace for a latest tv that does not use cable box.thes out of style
Mar 02, 2007 | Panasonic DMR-EH75 DVD Recorder/VCR/HDD...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
181 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
