FixYa.com
Tags:
Fuji FinePix S5000 Digital Camera
Fujifilm S5000 problem (by 2 users)
By Perkins - usenet poster
We've used our S5000 for just over a year now - i.e. it is now just
outside of warranty!
We've found the camera to be generally excellent, but in the last month
it's started having a problem - when we replace the AA batteries it
loses all the settings - the date and time is lost, the megapixel
setting is reset to 1M, the volume of the shutter and beep goes back up
to annoyingly high.
Can anyone help solve this problem? Does anyone know if there's some
internal battery in the S5000 that can be replaced or recharged? Any
suggestions appreciated.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by liveoutside, posted on Mar 03, 2008
Yes, the camera loses all settings while the batteries are being changed. It was a gift to my wife and she loves the performance, ergonomics, and enjoys it more than any gift I have ever bought her. She's very proud of this camera, and then this happened 2 months out of warrantee. I could not get any answers out of Fuji as to whether there was a problem and what it might be. I suspected a back up battery issue as well. I never received any answer from Fuji. As I’ve seen posted elsewhere, I rate their customer service a zero.
So I send the camera to the authorized service center for an estimate. They confirm that the problem is a capacitor (there is no battery), and replace the capacitor for $108. Now 18 months later the problem is back.
So, did they replace a capacitor, or a microchip? The service center won’t let me talk to a tech, and the receptionist isn’t helpful with the science. Does the camera have a problem with both of these components? If I have it repaired am I replacing the same component or a new one?
I would spend the money on the camera if I could be sure that this problem was fixed for good.
I feel cheated by Fuji that they will not support me for a product defect, even if all I ask for is correct information.
Best Solution
posted on Mar 18, 2008
FixYa! (100)
liveoutside
Rank:Apprentice Apprentice
Rating: 90%, 3 votes
Hi everyone,
I posted the “memory loss when changing batteries problem” (liveoutside). I responded to a poster who suggested a battery and I purchased some parts.
I have now changed the battery and the camera works flawlessly.
Once and for all here is the truth.
The Fuji S5000 camera does indeed have a button battery to maintain memory when the batteries are changed. Unfortunately is located deep inside the camera and is soldered in place. Furthermore the necessary nature of the micro-electronics makes disassembly not for the timid.
So, you can pay a service center to repair your camera and it will be fine…..for about a year. It is up to each of us to decide if it is worth it (fortunately I can change mine, although it is NOT fun).
All of this said, I want everyone to know that this is Fujigate, a cover-up. I have been told by Fuji that there is no battery. I was told by my authorized service center that there is no battery, but a capacitor. The service center that repaired my camera gave me an invoice that states “replaced memory capacitor”.
Ladies and Gentlemen, it is not a capacitor! When I paid to have it repaired I expected a permanent repair of a faulty component. Capacitors are good for hundreds of thousands of cycles, and batteries are not. I don’t believe that a capacitor would do this job.
For some reason Fuji’s design of this model includes a battery that provides inadequate service life. If that was going to be a part that needed frequent replacement, they should have provided a door on the chassis of the camera that accommodated easy replacement of this battery.
I think they know they screwed up, don’t want to take responsibility for it, and their solution is to keep it quiet, let us throw our cameras into the landfill and move on, hoping no one’s the wiser (wink).
You can be sure that I will confront the service center and Fuji in writing and I would recommend that you all do the same (do not call or e-mail, even today it takes snail mail to make people know you’re serious).
If you need any factual support of battery part numbers and circuit board locations for your correspondence please feel free to contact me @blueleaderron@hotmail.com
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 09, 2005
Helpful (85)
Horner
Horner - usenet poster
Rating: 0%, 0 votes
Yes, your S5000 contains a battery (lithium 'button' cell, I believe) which,
ordinarily, would enable the camera to store all the user settings. It
sounds as though yours (or its recharging circuitry, which is less likely)
has died. A year is rather a short life for these batteries in these cameras
but by no means unheard-of, unfortunately.
I don't know how easy it is to change the battery yourself on the S5000. If
you phone your nearest Fuji service centre and tell them how disappointed
you are (but otherwise very happy with their product... ;-) ) you may find
that they will do the job free - Fuji UK can be very good like this at
times.
You might find advice on changing the battery yourself on the forums of
various digital camera sites, such as www.DPReview.com - the Fuji forum
there is at
http://forums.dpreview.com/for ums/forum.asp?forum=1012
Hope this helps, and good luck with your camera.
Cheers,
Nionyn
Solution #3
posted on Jun 01, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
Fuji S5000 doesn't have an internal battery...it's a known motherboard/internal memory chip failure. Basically, they put a chip in there that will only last a couple years and then you either have to replace it (for a couple hundred bucks) or deal with correcting the settings everytime you change batteries (which will be more often now that some battery power is now dedicated to holding that internal memory settings). FujiFilm doesn't seem interested in correcting the issue via customer service either, very much a bummer!!
Solution #4
posted on Jun 26, 2008
Not Rated (0)
hammered
Rating: 0%, 0 votes
My solution to this is simple. While having to set the time, date, resolution, etc. every time I change the batteries is an inconvenience, I don't feel it's worth the money to have it repaired. However, there is a way to change the batteries without losing the settings. Do this...
1st - On the outside of the battery door, mark the orientation of the battery teminals as they relate to each battery position. In other words, mark a small + or - to indicate how the batteries are installed.
2nd - Before you open the door to change the batteries, lay out the new ones so they are ready to drop in quickly. Use your marks (+ and -) to remind you how they are installed.
3rd - Open the battery door and dump the batteries out quickly. Now grab your new batteries 2 at a time. They should already be oriented to drop in the slots. Drop them in quickly and then snap the door shut.
If you can change the batteries in less than 10 seconds or so, the camera will retain the settings.
With a little preparation and quick movement, you can save yourself the time and money for something that is really just an inconvenience.
I hope this helps...
Solution #5
posted on Jan 30, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I suggest you get it changed over now! The little button cell will start to leak, and corrode the board around it... causing a need for a new camera! One of the chips on the board can also cause the battry to fail, if it shorts the battery. I'm just doing mine now in my S3500. I'm wondering whether to buy another Fuji camera or not...
Can you Help with these Digital Cameras problems?
finepix 2700
the camera instuctions are in... Answer This...
change the picture size
Hiya how do i change the... Answer This...
printing date on photos
I have the Fuji E510 and can't... Answer This...
Zoom error
Hi.. when I turn the camera on... Answer This...
Lumix DMC-FC7, the flash does
Lumix DMC-FC7, the flash does... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
