Question about Maytag Atlantis MAV6451 Top Load Washer
Squelling noise The washer squeels when it is doing anything but filling. Can you help. I checked the drive belt and it seems fine, but it could be the problem. The unit is about three years old. Thanks Bill
  • 1 more comment
  • Anonymous Dec 13, 2007
    I HAVE THE SAME PROBLEM WITH THE SQUEELING NOISE. WASHED A QUILT (HEAVY ONE) AND SINCE THEN I HAVE HAD THIS PROBLEM. THE WASHER STILL WASHES AND SPINS, BUT MAKES A LOUD NOISE.
    CHARLIE
  • JohninDallas Dec 16, 2007
    I have a problem with screeching noise when it stops washing or spinning. Maybe related. Machine is also about 3 years old and lightly used. In my opinion it's a piece of junk.
  • keeuqs Jan 14, 2008
    The squeeling suddenly stopped and has not reqppeared. I suspect that the Solution #1, (object stuck in the water pump) could very well be the solution.
    Thanks for the help.
    Scholar:
  • 196 Answers
Check the water pump. Remove the belt and turn the pump by hand in both directions. If there is a problem you will feel the pump try to grab. A lot of times some small objects that get in the washer and end up in the pump and causes everything from clicking noises to full stop.
Posted on Jan 14, 2008
  • Elmer Vest
    Elmer Vest Jan 15, 2008
    keeuqs There is still a possibilty that the pump has been damaged. If the sound comes back, check the pump.
SOURCE:
I have a maytag atlantis washer that will completely fill at the beginning of the cycle, stop, then make a very loud squeeling noise, stop, and now will not advance through any cycle...even manually. We...
The not completly filling and squeeling makes me want to look at the screen on the water valve that the hoses attach to on the rear of the machine for blockage preventing water flow,to me the squeeling is the solonoids on the water valve calling for water yet no water coming in. IF you manually fill the washer using buckets of water/a hose what will happen? perhaps try that!!
Also if you have the "aquaflow flood stop" hoses the internal stopper in the hose is bad,replace hoses using standard hoses
Good luck,i hope this helps you to fix your washer,
Gene
Aug 09, 2011 | Maytag Atlantis MAV9501E Top Load Washer
I have a Maytag washer that the agitator is not working , I makes a squealing noise, How do I repair this? Thanks
Your problem may be a seized water pump with the motor turning the drive belt on a water pump pulley that is not turning (belt squealing). Or the noise could be originating from a water pump that has a noisy/bad bearing. If the pump pulley is turning and making the noise, you may be able to lubricate the pump shaft with some quality shaft lubicant (no guarantee that the noise will cease)! If other problem, contact an appliance service company.
Feb 20, 2010 | Maytag Washing Machines
I put a load of wash in the washer filled with
im guessing this is a performa? if so you may have something cought in your pump. remove the obstruction and check to make sure the pump is free, then replace the belt. the belt should seem a little loose as it needs to slip to get the machine up to speed in the spin
Feb 07, 2010 | Washing Machines
My 2006 jeep wrangler was making a noise like a belt squeeling drove about 5 miles noise stopped engine light appeared and oil pressure went to 0 (Jeep only has 38,000 miles)I imediatly turned engine off i...
have truck scanned for code can be anything oil pump timing chain etc also check warranty before doing any work most drive trains 5yrs- 100,000 miles
Oct 07, 2009 | 2006 Jeep Wrangler
Kenmore washer (model # 110 24872300) won't agitate.
Your machine has no belt. It has a direct drive coupling. The direct drive coupling between the motor and transmission must be replaced.
May 20, 2009 | Kenmore 24902 Top Load Washer
Squeeling Noise (from the pully pump I think) Maytag MAV8600AWW
you need to replace the pump the pump bearings are starting to wear out eventually the washer will not drain
Dec 20, 2008 | Maytag MAV8600 Top Load Washer
94 nissan maxima se, Squeeling loud when car is started.
I can't tell exactly what it is since I cannot hear it, but in most cases it's a belt. Check that first, or have a friend help you - one of you can start the car and the other one can look under a hood to search for the squeeling part.
Sep 16, 2008 | 1994 Nissan Maxima
Washer help
Check the lid switch. Some units use a safety lock out. If it is not working then the unit will not drain or spin.
Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Maytag Atlantis MAV6451 Top Load Washer Logo
41 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
