Question about Xybernaut Atigo T/HB Network Terminal
Windows PW Problem
Aquired Atigo in motorhome w/Windows XP Embedded. Normally it boots with no PW for windows xp. All of a sudden it's asking for a password. I believe one of the shell programs is being booted and I don't know how to get it back to selecting the normal admin which requires no pw! Can someone HELP! I am locled out now!
  • 61 Answers
I've solved this by going in as Admin, and removing the .Net user account that MS sets up with install of .Net. If you can't get into the machine at all, look for a copy of Hiren , it's a bootable CD that can remove XP passwords and much more, just be careful with it!!
Good Luck!
Posted on Jan 02, 2008
How to fix my acer extensa 4630z? Its boot manager is missing or corrupted.
First you need:
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
Watch for a Press any key to boot from CD... message similar to the one shown above.
Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, just restart and try to boot to the Windows XP CD again.
  1. Enter Windows XP Recovery Console. The Recovery Console is an advanced diagnostic mode of Windows XP with special tools that will allow you to restore the boot.ini file.
When you reach the command line (detailed in Step 6 in the link above), type the following command and then press Enter.
bootcfg /rebuild
The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
The first prompt asks Add installation to boot list? (Yes/No/All).
Type Y in response to this question and press Enter.
The next prompt asks you to Enter Load Identifier:.
This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
The final prompt asks you to Enter OS Load options:.
Type /Fastdetect here and press Enter.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Apr 01, 2015 | Acer Extensa 4630z
Installed win 7 but want restore to xp
To reinstall win XP from usb flash drive you need WIndows XP cd, 1 gb flash drive and Novicorp WinToFlash. Download WinToFlash to your computer and follow instructions to transfer Windows XP from cd to flash drive, After that boot your notebook from usb device and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon" then install win xp normally, but format C partition. After first start of your notebook boot again from flash drive in "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon". Now windows is starting, go to start/my computer right click on it and go to properties in this windows go to advanced tab and there go to startup and recovery, click on settings, in new window go to edit tab and in new window change the line "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP" /noexecute=optin /fastdetect" after windows XP write the type of your XP Professional, Home Edition, or Media Center. Now you can remove usb flash drive and boot normally from hdd.
Nov 12, 2012 | Advent 4211c Notebook
Felling to boot from HDD or USB . DOES NOT RECONIZE THE USB PORT . i want to format the hard drive then reinstall windows 98 or windows xp.
HELLO, Is your laptop booting normally before it suddenly stops booting from the HDD.If it is this case then you need to format the HDD with window xp, i suggest.reason being that window xp support USB automatically. hope this helps Regards
Nov 26, 2010 | Compaq Evo Notebook N400c
How can i repair or replace boot.ini in windows xp
bootcfg /rebuild
Nov 03, 2010 | Computers & Internet
How do I rebuild the MBR?
You will need an XP install CD for this and also set the CD/DVD drive as the first boot device.
  1. Watch for a Press any key to boot from CD... message similar to the one shown above.
  2. Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
  3. When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
  4. The Recovery Console is now loading but needs to know which Windows installation to access. Most users only have a single Windows XP installation so the choice is usually clear.
    To the Which Windows installation would you like to log onto question, press 1 and then Enter.
  5. The Recovery Console now needs to know the administrator password for this Windows XP installation. Unless you are using a PC in a sizable business network, the administrator password is most likely the same password you use to access Windows XP on a daily basis. To the Type the Administrator password request, enter the password and press Enter.
    Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
  6. Type fixmbr and then press Enter.
  7. The fixmbr utility will write a master boot record to the hard drive that you're currently using to boot into Windows XP. This will repair any corruption or damage that the master boot record may have.
  8. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
    Assuming that a corrupt master boot record was your only issue, Windows XP should now start normally.
Regards.
Aug 16, 2010 | Microsoft Windows XP Professional SP3 Full...
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
May 22, 2009 | Microsoft Windows XP Professional SP3 Full...
I recive\system 32\hal.dll
The first thing to check is your boot order.. do this when the pc starts up by pressing which ever key is indicated to enter 'setup' usually f2, f12, or delete. and look through for boot devices or boot sequence. make sure it's floppy, cdrom, hdd drive which may be listed or hard drive, internal drive, etc).
Do you have your windows disk? If so try this... put in the cd and restart the computer and when prompted to "pressany key to boot from cd' do so. Enter Windows XP Recovery Console by click on R. The Recovery Console is an advanced diagnostic mode of Windows XP with special tools that will allow you to restore the boot.ini file.
  1. When you reach the command prompt type the following command and then press Enter.
  2. bootcfg /rebuild
  3. The first prompt asks Add installation to boot list? (Yes/No/All).
  4. Type Y in response to this question and press Enter.
  5. The next prompt asks you to Enter Load Identifier:.
  6. This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
  7. The final prompt asks you to Enter OS Load options:.
  8. Type /Fastdetect here and press Enter.
  9. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
  10. Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Dec 02, 2008 | Microsoft Windows XP Professional With...
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
Repair start up failure
Well it depends on how severe is your start up problem, if the OS still loads lets say on Windows XP more or less you just have to repair the boot.ini, if you have your Windows XP CD load it to your computer(make sure that on the BIOS setup the intial boot devce must be your CD ROM) When the initialization finished press R to open the command prompt the type the following;
bootcfg /rebuild
Oct 04, 2008 | Computers & Internet
I am in need to install recovery console
Here's How:
Boot From the Windows XP CD
Press R to Enter Recovery Console
Choose the Windows Installation
Enter the Administrator Password
Make Necessary Changes in Windows XP Recovery Console
The Recovery Console is now fully loaded and the cursor should be sitting at the command prompt, ready for input, as shown in the screen shot above.
Make any changes necessary in the Windows XP Recovery Console. When complete, take out the Windows XP CD and type exit to restart the computer.
  1. When you reach the command prompt (detailed in Step 6 in the link above), type the following command and then press Enter.
    bootcfg /rebuild
  2. The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
  4. The next prompt asks you to Enter Load Identifier:.
  5. The final prompt asks you to Enter OS Load options:.
  6. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Show your appreciation by rating it.
May 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Xybernaut Atigo T/HB Network Terminal Logo
156 people viewed this question
Top Xybernaut Computers & Internet Experts
David Payne
David Payne
Are you a Xybernaut Computer and Internet Expert? Answer questions, earn points and help others
