Question about Visonik V408XT 250W x 2 Car Amp Car Audio Amplifier
Visonik 2-ch amp getting too hot and shutting down
I just purchased a Visonik V408XT. I have hooked it up to an MTX Sledgehammer box with 3 - 10" Thunder 4500 subwoofers. The box is wired up to one channel at 4 ohms. It has an RMS rating of 635 watts.
I purchased this amp because the bridged power is 800 X 1 @ 4ohms. What I was told is - using an amp that pushes more power than the RMS power of your subwoofers was a good thing. I was told that by doing this, it would eliminate the amp "overheating" because it could "push more, but didn't have to work so hard, which in turn would not overheat the amp". I had this set up installed by circuit city.
I do not have the gains turned up to the max at this point. Currently, they are about halfway. I have used 4 gauge wiring from the battery to a 1.2 farad Tsunami capacitor. (The capacitor is usually between 12.1 & 13+ volts) From the capacitor I have 8 gauge wiring powering the amps. (I also have a Visonik 204XT 4-ch amp that is running the components and coaxials, and it seems fine) I have 4 gauge ground wire as well, with 8 gauge ground wire routed through the capacitor to the amps. Looking at it, the ground doesn’t seem to be very good. They grounded it to a spot in the trunk, but it doesn’t look like they removed hardly any paint from the spot they grounded at? I’m not sure if that makes a difference?
My problems that I am having are –
1. The amp gets EXTREMELY hot after about 20 minutes of continuous play?
2. When I am listening to it at any level, I hear a popping noise or a flicker noise when I push the button to roll down my car windows. Or if I push the sunroof button, to open that, it affects the amp. It also makes a noise if I hit the power door locks button.
3. When I turn on my car, the sub amp makes a sudden “thump” noise? As if a sudden jolt of music is going through it? (but nothing is on yet, no music playing or anything) Its like it happens when it powers up or something?
I hope I have provided enough info to hopefully get my questions answered. I don’t want to have to take my car back to the shop if it’s a simple fix?
Thanks so much!!
I have the same amp that i just bought but mine dont do that. do you ever think that youu are a dumbshit and didnt know what the ******** were doing.
Posted on Jul 23, 2009
    Problem Solver:
  • 7 Answers
1) Visonik= ewww... i had a kit of theese and ew. i tried to call em, email them and notthiiing ever worked.
2) amp needs its space.
3) try little fans.. u can search in audio stores, they are arround 6 bucks each. not any fan, but AMP fans.
4)check rca's. ur power and rca cant be in same side.
5) seek profesional install if it doesnt help out..
Posted on May 24, 2008
    Problem Solver:
  • 8 Answers
First i have to ask if you ran the rcas on the same side as you did your power wires. that would result in the interference you're recieving. the rcas should be on one side of the vehicle and the power wires on the other. if you're unsure of the grounding site then take the time to properly clean it and reinstall. also understand that you amp having adequate breathing room is very important. without enough airspace your amp will surely overheat.
Posted on Dec 05, 2007
4 Suggested Answers
SOURCE:
Cerfer39
  • 709 Answers
SOURCE: confused
Hi jimmyjames,
How do you have the wires hooked from the sony reciever to the inputs on the mtx?
 Sounds like your Remote wire is way too big. it should be 14 guage.  It only sends a low voltage low amp signal.
Another thing that could be messing up the sounds is the routing of the wires.  you should have the power supply wires separate from the Audiop signal wiring.  Power should run down the Driver side and Audio down the passenger side.
When you answer I may be able to tell you more.
Posted on Oct 19, 2007
  • 86 Answers
SOURCE: Schematic for MTX Blue Thunder Pro 752 amplifier
hello ..try this ...www.eserviceinfo.com...takes a bit of working out how to get them .when you do .you have to download bitzipper (these are a rar file)...then adobe 8 ..bitzipper can convert to a pdf flie so you can read them...hope you have some luck
Posted on Feb 12, 2008
  • 84 Answers
SOURCE: mtx thunder 304 4ch red amp light comes on but no audio
if the lights on and there is no sound it's either a cd player issue or your rca issue or the inputs for rca's on the amp are no good. or you have your subs wired at a wrong load to your amp and it is in a constant protection to avoid burning up.
Posted on Jun 14, 2009
ON MY Pioneer PRS-X720 Car Audio Amplifier WHEN I TRY TO HOOK UP THE BRIDGE LITTLE SOUNDS COMES OUT THE SPEAKERS I HAVE TWO 12S MTX THUNDER IN THEY ARE IN A 2OHMS BOX BUT WHEN I HOOK UP JUST ONE CHANNEL...
From the specs this amp can only handle 4ohms when bridged but can handle 2ohms when it's not bridged
Specifications
  • Continuous Power (20Hz-20kHz, 0.04% THD)
    • 2 ch: (4 Ohm) 100Wx2
    • 2 ch: (2 Ohm) 200Wx2
    • 1 ch: (4 Ohm) 400Wx1
  • Maximum Power (EIAJ)
    • 2 ch: (4 Ohm) 250Wx2
    • 1 ch: (4 Ohm) 750Wx1
  • Frequency Response: 10Hz - 50kHz (0,-1dB)
  • Total Harmonic Distortion: <0.01% (1kHz, 4 Ohm)
  • Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
  • Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Hope that helps.
Nov 08, 2010 | Pioneer PRS-X720 Car Audio Amplifier
Mtx thunder 6152 is getting way to hot and shuts its self off when it get really hot
okay, first thing i would do is turn down your gain. Sounds like you are over working the amp thats wire your amp gets hot and shut off, it's going into protection mode. Is your amp enough for your subs. Some times not getting enough power to your amp might do this too. But if your subs wattage is way over your amp watts, you need to upgrade your amp. Also check your subs and see how the are wired up with the ohms, And see if your amp can take a 1 ohm stable load or how ever it's wired up at. hope this was helpfull.
May 13, 2010 | MTX Thunder 6152 Car Audio Amplifier
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
Can you help with my wiring?
The more amp you are pushing the better. Better too much amp then not enough. How many watts per speaker? less then the amp I hope. When you need decibles the more air you push the louder it will be. Enclose in a MDFB enclosure or plexiglass and feed towards each other and port the box to the sides. This will cause some annoyance. We ran 2 rockforts @1000 watts and abtained 137dc before the back windshield blow out,,lol
Mar 09, 2010 | MTX 6001 Car Audio Amplifier
Does it sound hot cool and bad ***
Hello dylanholick,
Visonik is somewhat low-end car audio and band pass enclosures in general usually produce rather muddy and boomy bass. It will probably sound "bad", but not hot, and not cool.
If you aim is a good self-contained system with amp, sub and enclosure all in one, why not consider an Infinity Basslink, MTX Thunderlink, or perhaps a Bazooka. They're all available at www.crutchfield.com for little more than you'll pay for the Visonik and any of them will definitely sound better.
Hope this helps.
Jul 14, 2009 | Visonik 10" 500-Watt Single Bandpass...
Amp in protect
DUDE CHECK UR WIRE .... AND INSIDE UR AMP THERE MIGHT B A SHORT CIRCUIT OR UR AMP GROUND PLUG INSIDE MUST BURNT OUT
Jun 20, 2009 | Visonik V408XT 250W x 2 Car Amp Car Audio...
Visonik amp problem... amp goes in and out of protection
Check for intermittent shorts on the speaker leads.
Turn down the volume control on your head unit while operating the amp, you could be over driving the amp.
Remove Speaker leads and reset the amplifier. IF the protection LED still comes on amplifier is faulty.
Below is the link to put in a help request with the manufacture for repair.
http://www.visonikcaraudio.com/category.jhtm?cid=27
Mar 25, 2009 | Visonik V408XT 250W x 2 Car Amp Car Audio...
MTX 5500 SLEDGEHAMMER 12" ENCLOSURE
According to MTX they need 1.25 cubic ft per sub sealed and 2 cubic feet vented. Most pre-fab boxes will work for those subs.
Jan 06, 2009 | MTX Dual 12" Subwoofer Enclosure (Bs212s)
Manual
run a wire from the battery to the place u are putting the amp. place a fuse in that wire no more than 10 inches away from the positive batt terminal. find a bolt near the amp and see if it is grounded. if so connect a wire from the bolt to your neg terminal on the amp. then run a remote wire and your rca from your radio to the amp. then connect a set of speaker wire from the amp to the subs or speakers
Apr 12, 2008 | Visonik V408XT 250W x 2 Car Amp Car Audio...
Visonik V408XT 250W x 2 Car Amp Car Audio Amplifier Logo
588 people viewed this question
Top Visonik Car Audio & Video Experts
Mike Duncan
Mike Duncan
Dalynn Turner
Pierre Laplante
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
